[Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Fri Sep 16 02:05:39 PDT 2016
There was another report of Shapefile corruption earlier with 2.14 which I thought it could be side effects of the solution for #11007:
http://hub.qgis.org/issues/15407
Cheers,
Saber
-----Original Message-----
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Giovanni Manghi
Sent: 16 September 2016 09:55
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
Hi all,
> While I've hit this issue maybe 3 or 4 times in the last 2 months, I
> haven't been able to track down exactly what causes this. It seems
> related to using the split or reshape tool on a shapefile, then saving
> the changes and getting the errors "Cannot reopen datasource
> xxx.shp|layerid=0 in read-only mode" and "Data source is invalid
> (Unable to open xxx.shx or xxx.SHX.Try --config SHAPE_RESTORE_SHX true
> to restore or create it)" in the log.
> A full report is at http://hub.qgis.org/issues/15570
geez... this unfortunately sounds familiar... remember all the issues with deleted features and shapefiles opened in software other than QGIS?
Can this be something related to that?
cheers
-- G --
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
