[Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Sep 16 11:27:05 PDT 2016
I just tried to reproduce with QGIS 2.16.2 on Windows 10, I had no
problems using the "Split Features" tool on a shapefile, and saving. I
notice that the .dbf .shp .shx were modified properly.
(I did have a brain lapse to remember that the Split Features tool lives
in the /edit menu ha)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-09-15 10:08 PM, Nyall Dawson wrote:
> Unfortunately a fairly nasty regression has slipped in to 2.16 and is
> still present on master. This results in shapefile corruption in
> certain circumstances.
> While I've hit this issue maybe 3 or 4 times in the last 2 months, I
> haven't been able to track down exactly what causes this. It seems
> related to using the split or reshape tool on a shapefile, then saving
> the changes and getting the errors "Cannot reopen datasource
> xxx.shp|layerid=0 in read-only mode" and "Data source is invalid
> (Unable to open xxx.shx or xxx.SHX.Try --config SHAPE_RESTORE_SHX true
> to restore or create it)" in the log.
> A full report is at http://hub.qgis.org/issues/15570
> Hopefully we can resolve this before the next round of releases. In
> the meantime, there's a workaround for recovering data:
> In the same folder as the shapefile there'll be additional files
> "xxx_packed.shp" and "xxx_packed.shx". Renaming the "xxx_packed.shx"
> file to "xxx.shx" allows the original shapefile to be reopened.
> Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
