[Qgis-developer] Warning - shapefile corruption on 2.16/master and how to recover
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Sep 16 15:00:55 PDT 2016
On 2016-09-16 3:53 PM, Even Rouault wrote:
> One of my hypothesis is some bad interaction with the "connection pool".
> Could you (or anyone) open the attribute table before doing the edits,and do
> the edits and commit them no more than 60 seconds afterwards ? I'm not sure
> but this might perhaps also require the shapefile to be big enough (several
> thousands of features).
Here was my next test:
- download OSM land polygons for the world, unsplit:
http://data.openstreetmapdata.com/land-polygons-complete-4326.zip
424MB 568,635 features <--- big test!
- add shapefile to QGIS 2.16.2 view
- open attribute table
- start editing
- after a while waiting for nodes to appear as QGIS works, message is
displayed of "qgis-bin.exe has stopped working"
With QGIS 2.14.0:
- exact same issue when starting editing of that layer
With QGIS 1.8.0:
- able to click start editing and no crash as nodes are displayed for world
- able to use "Split Features" and save edits
- seems to write changes to .dbf .shp .shx (to be honest, changes don't
look like a valid feature split, hard to tell, but it seems a few more
feature records were added)
You likely aren't happy that I tried with such large of a file, but, it
was honestly the first big file that I found.
other test for fun:
- checked layer summary through ogrinfo
- indexed the .shp with the shptree utility (generates 22MB .qix index
file, wow)
- created a small MapServer mapfile with only that layer, for world extents
- generated map image through MapServer, recording layer draw speed (cool!)
- tried to compare that speed, to QGIS 2.16.2 loading that same
shapefile (doing both a same time)
Fun results! Any guess how MapServer did? :)
Honestly I didn't plan to check that, and that is not why I tried to
help here, but when I saw QGIS having a hard time with this large file,
on a 16MB RAM new machine, I thought 'hmm i wonder how MapServer would
handle this huge file?' For one of the previous WMS Benchmarking
exercises at an old FOSS4G event I tested with a 1GB shapefile, and we
had to fix the indexing for MapServer...so it is good to try to push
limits once in a while.
sorry if i offend anyone with these tests, was just having some fun
pushing MapServer as well.
Let me know if you need more tests.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
