[Qgis-developer] best way to provide a python lib to both plugin and processing?
Richard Duivenvoorde
rdmailings at duif.net
Sat Sep 17 09:26:21 PDT 2016
I have a python plugin in which one of the core functions is to retrieve
some data via a custom protocol.
Let's call this a 'data-provider'.
It could be handy if we could also use that data-provider in a
processing script or model.
So Question: how to distribute/create a python library which can be used
in both plugins and processing?
Should I do that via pip?
Or is a module in a plugin the best way (as that is I think easiest to
get 'installed' by users)?
But is that module then easily available in processing scripts?
Or should I create a processing geo-algorithm for it? But then my
question is: how to distribute that easily?
Do we have some 'api' that a processing script is supposed to use?
Maybe it is possible to create a generic 'api' to make it easy to load
libs for plugins/processing?
(Maybe even the same with the little dialog which is used: how to
provide/distribute that one)
Regards,
Richard
