[Qgis-developer] Python3 and cStringIO in processing
Arnaud Morvan
arnaud.morvan at camptocamp.com
Mon Sep 19 08:15:32 PDT 2016
Note that you could also add a symbolic link in .qgis-dev to output dir,
example :
ln -s <build-dir>/output/python/plugin/* $HOME/.qgis-dev/python/plugins/
And it should load processing plugin from output dir.
No need to make recurrent copies to install dir after that.
Arnaud
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 18/09/2016 13:24, Mathieu Pellerin a écrit :
> This error means that your python files have not passed through 2to3.
> Make sure PORT_PLUGINS flag is turned on.
> Also right now, the make script only runs 2to3 against the python code
> inside the output directory, it does *not* do so for the python code
> copied to your install location during "make install". You either can
> run QGIS from your output directory, or (as a temporary ugly hack)
> copy the content of the python folder in your output directory onto
> your installation's /share/qgis/python directory.
> Hope that helps.
> On Sep 18, 2016 6:02 PM, "Richard Duivenvoorde" <rdmailings at duif.net
> <mailto:rdmailings at duif.net>> wrote:
> Hi,
> testing Python3/Qt5 I get the following message:
> File
> "/home/richard/apps/qgis3/master/debug/share/qgis/python/plugins/processing/tools/vector.py",
> line 34, in
> import cStringIO
> According to:
> http://stackoverflow.com/questions/30377620/python-3-4-cstringio-vs-stringio
> <http://stackoverflow.com/questions/30377620/python-3-4-cstringio-vs-stringio>
> there is no cStringIO anymore in py3
> do I miss a compile/install step or isn't processing not yet ready to
> use yet?
> Regards,
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe:
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160919/a65f7125/attachment.html>
