[Qgis-developer] Multiple Fields in R-Processing
matteo
matteo.ghetta at gmail.com
Thu Sep 22 05:48:34 PDT 2016
Hi guys,
I have a small problem with the integration of the MultipleField
parameter in the R-Processing script.
The trial script is super simple:
##[R-Geostatistics]=group
##l=vector
##X=multiple Field l
>X
So I just want to understand how can I extract the single fields of the
parameter.
Doing so the script runs, but I always get the same error:
Source: "/tmp/processing510ec5d19fc74c0582fbe8983bd85e66", layer:
"1474548069.5615"
with 102 features
It has 6 fields
multiple Field l="Gruppo;SN"
Error: unexpected symbol in "multiple Field"
Execution halted
I tried several other combinations but I'm running out of fantasy.
With the selection parameter it is simpler:
##type=selection point;lines;point&lines
>type
and the output is 0 (so the first chosen).
The parameter can be accessed here:
import processing
from processing.core.parameters import ParameterTableMultipleFiel
Thanks guys
Matteo
