[Qgis-developer] Building on Ubuntu 14.04
Alessandro Pasotti
apasotti at gmail.com
Sun Sep 25 23:53:24 PDT 2016
On Sat, Sep 24, 2016 at 5:21 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le samedi 24 septembre 2016 16:34:36, Sandro Santilli a écrit :
> > On Sat, Sep 24, 2016 at 04:31:23PM +0200, Sandro Santilli wrote:
> > > I'm trying to build the master branch on Ubuntu 14.04.5
> > > but the build configuration fails with:
> > > CMake Error at cmake/FindQCA.cmake:60 (message):
> > > Could not find QCA
> > > Call Stack (most recent call first):
> > > CMakeLists.txt:296 (FIND_PACKAGE)
> > > I have libqca2-dev installed, and 2.14 branch builds just fine:
> > > -- Found QCA: /usr/lib/x86_64-linux-gnu/libqca.so (2.0.3)
> > > -- Found QCA OpenSSL plugin
> > > What changed between 2.14 and master wrt QCA ?
> > This seems to have changed:
> > diff qgis-2.14/cmake/FindQCA.cmake qgis/cmake/FindQCA.cmake
> > 23,27c23
> > < if(ENABLE_QT5)
> > < set(QCA_LIBRARY_NAMES qca-qt5 qca2-qt5)
> > < else(ENABLE_QT5)
> > < set(QCA_LIBRARY_NAMES qca qca2)
> > < endif(ENABLE_QT5)
> > 52c48
> > < PATH_SUFFIXES QtCrypto qt4/QtCrypto Qca-qt5/QtCrypto
> > > PATH_SUFFIXES QtCrypto qt5/QtCrypto Qca-qt5/QtCrypto
> > It looks like qca-qt5 is not packaged for ubuntu 14.04,
> > can I disable it ?
> Some time ago, I had rebuilt the whole stack of dependencies from sources.
> This was quite a pain for a few of them (one of the QT based lib. can't
> remember which one), especially to convince them to install to a custom
> prefix.
> You could take inspiration from Matthias' build recipees at
> https://github.com/opengisch/osgeo4travis/tree/master/docker/qt5 that are
> used
> to generate the
> https://github.com/opengisch/osgeo4travis/archive/qt5bin.tar.gz archive
> used
> on Travis-CI (but you can't probably directly use those binaries for 14.04
> as
> they are targetted for 12.04).
> > --strk;
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Spatialys - Geospatial professional services
> http://www.spatialys.com
I'm also trying to build on 14.04, I've installed QCA following this guide:
https://github.com/JPNaude/dev_notes/wiki/Using-the-Qt-Cryptographic-Architecture-with-Qt5#building-qca-on-linux
But this was not the last issue: GDAL is 1.10.1, Qt5 is 5.2.1 and the build
fails with:
/home/ale/dev/QGIS/src/core/qgsexpression.cpp: In member function ‘void
QgsExpression::detach()’:
/home/ale/dev/QGIS/src/core/qgsexpression.cpp:3835:15: error: no match for
‘operator>’ (operand types are ‘QAtomicInt’ and ‘int’)
if ( d->ref > 1 )
I've another machine with xenial and it builds just fine but it would nice
to be able to build on trusty too.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160926/c57e1a46/attachment.html>
