[Qgis-developer] Testing plugins against QGIS3 with Travis
Alessandro Pasotti
apasotti at gmail.com
Tue Sep 27 02:25:00 PDT 2016
On Tue, Sep 27, 2016 at 11:21 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
wrote:
> @Juergen Ah, so this is not possible? Thank you for clarifying - though I
> don't think the error I pasted above indicates that problem. Never mind.
> That means that the bet way to achieve this is probably...:
> @Ale I can see that that would achieve what I need. I only have two issues
> with this approach:
> 1. At the moment, my tests don't have to build QGIS, so they complete in
> less than three minutes
QGIS is already built into the docker images and you don't need to buld it
in a travis job (it would take too long) but yes, the docker pull operation
could take a while.
The advantage is that you can design and develop your tests inside QGIS,
because they are actually run inside a real QGIS instance, no need for
mocking.
> 2. I'd have to learn docker...
To use the available images you don't need to learn docker, but if you plan
to contribute yes.
> But I'll look into it. Thanks, both.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/Testing-plugins-against-QGIS3-with-Travis-
> tp5287867p5287962.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160927/0d51d572/attachment.html>
