[Qgis-developer] QGIS 2.16.3 Invert for Singleband pseudocolor still not working
C Hamilton
adenaculture at gmail.com
Wed Sep 28 06:40:38 PDT 2016
Thanks for the replay and hopefully it can be fixed soon. In the future I
will add some pictures when I find a problem.
All the best,
Calvin
On Wed, Sep 28, 2016 at 2:48 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 28 Sep 2016 4:46 PM, "Richard Duivenvoorde" <rdmailings at duif.net>
> wrote:
> > On 27-09-16 22:41, C Hamilton wrote:
> > > Several individuals have mentioned the problem with the Invert not
> > > working in 2.16.2 when styling a gray scale image with Singleband
> > > pseudocolor as the render type. I thought it would be fixed in this
> > > release, but it wasn't so I want to bring it up again as this is a
> > > problem for me.
> > > It works if the Mode is set to "Equal interval" or "Quantile" but it
> > > does not work with "Continuous." It works properly in QGIS 2.14.
> > Hi Chris,
> > sorry cannot help you, but it helps if you point to a relevant issue, or
> > in case there is not one, create a good issue: that is: provide a small
> > dataset, and maybe a picture with a desired img and one which is NOT
> > good. That gives devs a good starting point, AND shows that somebody is
> > at least interested enough to create a good issue report :-)
> That's good advice in general! FYI this is a known issue and there's a PR
> with a fix waiting review. I'll do that during freeze.
> Nyall
> > Regards,
> > Richard
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160928/9468df62/attachment-0001.html>
