[Qgis-developer] QGIS 2 master on Windows: lots of crashes when using the color picker dialog
Neumann, Andreas a.neumann at carto.net
Wed Sep 28 08:00:09 PDT 2016
Hi Tom,
Thank you for your tests. It is encouraging that others can reproduce.
This justifies that I'll do a bug report.
Meanwhile I also tested on Linux and it behaves the same like the
Windows version. More comments below.
On 2016-09-28 10:42, Tom Chadwin wrote:
> Confirmed with 0497e4a. Could it be limited to categorized renderers?
> Specifically, in my tests:
> 1. does *not* occur with single symbol or graduated renderer
I can confirm that. It happens for categorized and for rule based
renderers, but not for single symbol or graduated renderers.
> 2. in categorized renderer, does *not* occur if double click category icon
> in ToC
confirmed
> 3. in categorized renderer *does* occur if click layer (not category) in ToC
confirmed
Here is my bug report: http://hub.qgis.org/issues/15634
Thanks,
Andreas
View this message in context:
http://osgeo-org.1560.x6.nabble.com/QGIS-2-master-on-Windows-lots-of-crashes-when-using-the-color-picker-dialog-tp5288053p5288207.html
Sent from the Quantum GIS - Developer mailing list archive at
Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160928/02a8abe1/attachment.html>
