[Qgis-developer] QGIS master 3 compile problem
Andreas Neumann
a.neumann at carto.net
Fri Sep 30 07:25:17 PDT 2016
I am trying to compile master3 with python 3 and qt5.
During compilation I get an error around gdal and python-future which
may be corrupted:
[10/803] cd /home/an/dev/QGIS/ninja-build/src/crssync &&
/home/an/dev/QGIS/ninja-build/output/bin/crssync
Running from build directory!
- source directory: /home/an/dev/QGIS
- output directory of the build: /home/an/dev/QGIS/ninja-build/output
Synchronizing CRS database with GDAL/PROJ definitions.
Only 0 columns
Load srs db from: /tmp/srs.db
Loaded 498/499 from /usr/local/share/gdal/gcs.csv
EPSG 6966: not imported
EPSG 7082: not imported
Loaded 4636/4714 from /usr/local/share/gdal/pcs.csv
Loaded 184/185 from /usr/local/share/gdal/vertcs.csv
Loaded 153/154 from /usr/local/share/gdal/compdcs.csv
Loaded 149/150 from /usr/local/share/gdal/geoccs.csv
Loading epsg.wkt
Loading esri_extra.wkt
6072 WKTs loaded
CRS update (inserted:0 updated:0 deleted:0 errors:0)
No CRS updates were necessary.
[13/803] Generating ui_dialogAbout.py
FAILED: cd /home/an/dev/QGIS/ninja-build/python/plugins/GdalTools/tools
&& /home/an/dev/QGIS/scripts/pyuic-wrapper.sh /usr/bin/pyuic5
/home/an/dev/QGIS/ninja-build/output/lib
/home/an/dev/QGIS/ninja-build/output/python /usr/bin/python3
/home/an/dev/QGIS/python/plugins/GdalTools/tools/dialogAbout.ui -o
/home/an/dev/QGIS/ninja-build/python/plugins/GdalTools/tools/ui_dialogAbout.py
File "/home/an/dev/QGIS/scripts/pyuic-wrapper.py", line 26, in <module>
import qgis.PyQt.uic.pyuic
File "/home/an/dev/QGIS/ninja-build/output/python/qgis/__init__.py",
line 27, in <module>
from qgis.PyQt import QtCore
File
"/home/an/dev/QGIS/ninja-build/output/python/qgis/PyQt/QtCore.py", line
3, in <module>
from types import MethodType
File "/usr/lib/python3.5/types.py", line 166, in <module>
import functools as _functools
File "/usr/lib/python3.5/functools.py", line 21, in <module>
from collections import namedtuple
File "/usr/lib/python3.5/collections/__init__.py", line 32, in <module>
from reprlib import recursive_repr as _recursive_repr
File
"/home/an/dev/QGIS/ninja-build/output/python/reprlib/__init__.py", line
7, in <module>
raise ImportError('This package should not be accessible on Python 3. '
ImportError: This package should not be accessible on Python 3. Either
you are trying to run from the python-future src folder or your
installation of python-future is corrupted.
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 53,
in apport_excepthook
if not enabled():
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 24,
in enabled
import re
File "/usr/lib/python3.5/re.py", line 335, in <module>
import copyreg
File
"/home/an/dev/QGIS/ninja-build/output/python/copyreg/__init__.py", line
7, in <module>
Original exception was:
File
3, in <module>
File
7, in <module>
[13/803] Generating ui_widgetProximity.py
/home/an/dev/QGIS/python/plugins/GdalTools/tools/widgetProximity.ui -o
/home/an/dev/QGIS/ninja-build/python/plugins/GdalTools/tools/ui_widgetProximity.py
File
3, in <module>
File
7, in <module>
if not enabled():
in enabled
import re
import copyreg
File
7, in <module>
File
3, in <module>
File
7, in <module>
ninja: build stopped: subcommand failed.
Anyone has an idea and what is wrong/missing here?
Note that I self-compiled gdal/geos/proj. Not sure if it properly builds
python2 and python3 bindings simultaneously?
Thank you for any hints!
Andreas
