[Qgis-developer] CI testing: the straight truth
Matthias Kuhn
matthias at opengis.ch
Wed Jan 4 01:31:56 PST 2017
Hi Andreas, Nyall
I would also prefer this, I just sent them a mail and will get back to
you as soon as I get a response.
Mid-term we will still need to launch a project to update the system and
get away from the pre-built dependencies in osgeo4travis to a system
that is easier to maintain collectively but I'm happy if we can wait
with this a bit.
@Tom Chadwin:
agreed, that's a risk indeed
Best regards
Matthias
On 01/04/2017 08:21 AM, Neumann, Andreas wrote:
> Hi all,
> I agree with Nyall. We should try contracting the travis ci team and ask
> them if we could switch to unlimited build time. Even if this means
> paying a certain amount for the services (if it is a reasonable price).
> Matthias - could you please take a lead in contacting them?
> Thanks,
> Andreas
> On 2017-01-03 23:40, Nyall Dawson wrote:
>> On 4 January 2017 at 07:59, Matthias Kuhn <matthias at opengis.ch
>> <mailto:matthias at opengis.ch>> wrote:
>>> Hi René-Luc, hi all,
>>> This is something I have been afraid of for a couple of weeks.
>>> Short story: our builds just grew too big and a full build is taking
>>> more than 50 minutes to complete on the travis infrastructure.
>> Argh... what a pain! Still, I think in some ways this is a good
>> reflection of the exponential growth in QGIS unit tests since your
>> initial work introducing the CI infrastructure. I certainly would
>> never want to go back to the pre-CI days!
>> Just wondering- is there any chance sending an email to the Travis
>> crew could get an extension to this build time? I can't see anything
>> on their publicised plans, but perhaps they have a cheaper unlimited
>> build time option available for open source projects?
>> I'd like to see us exhaust these "easier" options first before
>> requiring someone to donate time into tweaking/changing the CI
>> infrastructure.
>> Nyall
>>> What
>>> keeps us alive at the moment is the persistent ccache so a full build
>>> actually never happens. If the ccache gets lost, we will need some black
>>> magic to get the builds started again (it's possible to slowly get the
>>> cache warm but not straightforward).
>>> What we could possibly do:
>>> - Modularize the build: e.g. astyle could very well be moved to a
>>> separate job along with other static checks like spelling. That would
>>> even have the advantage of a faster feedback for these analyses.
>>> But I'm not sure how much time we can actually get out of that.
>>> - Move dependencies into separate packages. We have some deps like
>>> qspatialite that are built as part of QGIS which I think could be
>>> installed as dependencies from a .deb. This will require quite a bit
>>> of work: moving travis out of the container based infrastructure to
>>> the sudo-enabled infrastructure, setting up a repo (e.g. ppa) with
>>> all sort of dependencies including qt 5 etc. This would be an option
>>> again since travis enabled caching also on sudo systems recently.
>>> This will be a quite large task to do.
>>> - Move to another system (managed infrastructure or self-hosted, there
>>> are a couple of services like circle ci, drone.io, jenkins, gitlab
>>> ci ...).
>>> This will be a quite large task to do with the risk that we run into
>>> yet another timeout, other technical issue or run a self-hosted
>>> infrastructure for which nobody really has the resources to maintain.
>>> Apart from this, there is also the dependency on some pre-compiled
>>> libraries in the osgeo4a repository. Keeping these up to date is not
>>> something we will want in the long term (I was hoping that travis would
>>> ship a more recent distro than trusty but haven't seen many hints in
>>> this direction yet).
>>> Bottomline: I don't think there's an easy fix but I think it's time to
>>> start thinking about the future.
>>> Matthias
>>> On 01/02/2017 03:03 PM, René-Luc Dhont wrote:
>>>> Hi Devs,
>>>> I would like to merge a PR https://github.com/qgis/QGIS/pull/3897 but
>>>> Travis cannot ccomplete the tests.
>>>> Would it be simple to fix travis ?
>>>> Regards,
>>>> René-Luc
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
