[Qgis-developer] CI testing: the straight truth
Neumann, Andreas
a.neumann at carto.net
Wed Jan 11 04:16:49 PST 2017
Hi Matthias,
Thanks a lot for dealing with this!
Andreas
On 2017-01-11 11:37, Matthias Kuhn wrote:
> Hi,
> I have just received the confirmation from travis that they boosted our
> build times to 90 minutes.
> I think that should keep us alive for the foreseeable future.
> Please let me use this opportunity to highlight the excellent support
> from their side!
> Matthias
> On 04/01/17 10:31, Matthias Kuhn wrote: Hi Andreas, Nyall
> I would also prefer this, I just sent them a mail and will get back to
> you as soon as I get a response.
> Mid-term we will still need to launch a project to update the system and
> get away from the pre-built dependencies in osgeo4travis to a system
> that is easier to maintain collectively but I'm happy if we can wait
> with this a bit.
> @Tom Chadwin:
> agreed, that's a risk indeed
> Best regards
> Matthias
> On 01/04/2017 08:21 AM, Neumann, Andreas wrote: Hi all,
> I agree with Nyall. We should try contracting the travis ci team and ask
> them if we could switch to unlimited build time. Even if this means
> paying a certain amount for the services (if it is a reasonable price).
> Matthias - could you please take a lead in contacting them?
> Thanks,
> Andreas
> On 2017-01-03 23:40, Nyall Dawson wrote:
> On 4 January 2017 at 07:59, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote: Hi René-Luc, hi all,
> This is something I have been afraid of for a couple of weeks.
> Short story: our builds just grew too big and a full build is taking
> more than 50 minutes to complete on the travis infrastructure. Argh... what a pain! Still, I think in some ways this is a good
> reflection of the exponential growth in QGIS unit tests since your
> initial work introducing the CI infrastructure. I certainly would
> never want to go back to the pre-CI days!
> Just wondering- is there any chance sending an email to the Travis
> crew could get an extension to this build time? I can't see anything
> on their publicised plans, but perhaps they have a cheaper unlimited
> build time option available for open source projects?
> I'd like to see us exhaust these "easier" options first before
> requiring someone to donate time into tweaking/changing the CI
> infrastructure.
> Nyall
> What
> keeps us alive at the moment is the persistent ccache so a full build
> actually never happens. If the ccache gets lost, we will need some black
> magic to get the builds started again (it's possible to slowly get the
> cache warm but not straightforward).
> What we could possibly do:
> - Modularize the build: e.g. astyle could very well be moved to a
> separate job along with other static checks like spelling. That would
> even have the advantage of a faster feedback for these analyses.
> But I'm not sure how much time we can actually get out of that.
> - Move dependencies into separate packages. We have some deps like
> qspatialite that are built as part of QGIS which I think could be
> installed as dependencies from a .deb. This will require quite a bit
> of work: moving travis out of the container based infrastructure to
> the sudo-enabled infrastructure, setting up a repo (e.g. ppa) with
> all sort of dependencies including qt 5 etc. This would be an option
> again since travis enabled caching also on sudo systems recently.
> This will be a quite large task to do.
> - Move to another system (managed infrastructure or self-hosted, there
> are a couple of services like circle ci, drone.io, jenkins, gitlab
> ci ...).
> This will be a quite large task to do with the risk that we run into
> yet another timeout, other technical issue or run a self-hosted
> infrastructure for which nobody really has the resources to maintain.
> Apart from this, there is also the dependency on some pre-compiled
> libraries in the osgeo4a repository. Keeping these up to date is not
> something we will want in the long term (I was hoping that travis would
> ship a more recent distro than trusty but haven't seen many hints in
> this direction yet).
> Bottomline: I don't think there's an easy fix but I think it's time to
> start thinking about the future.
> Matthias
> On 01/02/2017 03:03 PM, René-Luc Dhont wrote: Hi Devs,
> I would like to merge a PR https://github.com/qgis/QGIS/pull/3897 but
> Travis cannot ccomplete the tests.
> Would it be simple to fix travis ?
> Regards,
> René-Luc
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer _______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170111/5cf6d512/attachment.html>
