[QGIS-es] actualización Taudem - Qgis 3.x
Eddison Araya eddisonjose en gmail.com
Mar Mayo 21 07:26:50 PDT 2019
Hola! que interesante!
acabo de realizar la prueba de instalación instalando Taudem desde  ZIP y
me sucede lo mismo!
Saludos
Eddison
El mar., 21 may. 2019 a las 9:06, carlos h (<carloslda256 en gmail.com>)
escribió:
> En mi caso lo que he hecho es descargar de aquí:
> https://github.com/alexbruy/processing-taudem/archive/master.zip
> Ir  a QGIS 3.6.2  - Complementos - Instalar desde Zip
> Y luego pasa esto:
> No se pudo cargar el complemento 'processing-taudem-master'
> ModuleNotFoundError: No module named 'processing_taudem'
> Traceback (most recent call last):
>   File "C:/PROGRA~1/QGIS3~1.4/apps/qgis-ltr/./python\qgis\utils.py", line 309, in loadPlugin
>     __import__(packageName)
>   File "C:/PROGRA~1/QGIS3~1.4/apps/qgis-ltr/./python\qgis\utils.py", line 672, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "C:/Users/Usuario/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\processing-taudem-master\__init__.py", line 28, in
>     from processing_taudem.taudemProviderPlugin import TauDemProviderPlugin
> Versión de Python: 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC
> v.1914 64 bit (AMD64)]
> Versión de QGIS: 3.4.6-Madeira Madeira, cc0e375a9f
> Ruta de Python:
>    - C:/PROGRA~1/QGIS3~1.4/apps/qgis-ltr/./python
>    - C:/Users/Usuario/AppData/Roaming/QGIS/QGIS3\profiles\default/python
>    - C:/PROGRA~1/QGIS3~1.4/apps/qgis-ltr/./python/plugins
>    - C:\CURSO_PYQGIS\SCRIPTS
>    - C:\Program Files\Hexagon\ERDAS IMAGINE
>    2015\usr\lib\Win32Release\pythonC:\CURSO_PYQGIS\SCRIPTS
>    - C:\PROGRA~1\QGIS3~1.4\bin
>    - C:\Program Files\QGIS 3.4\bin\python37.zip
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\DLLs
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\win32
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\win32\lib
>    - C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\Pythonwin
> El mar., 21 may. 2019 a las 7:00, carlos h (<carloslda256 en gmail.com>)
> escribió:
>> Hola Luigi, muy amable de su parte
>> Saludos cordiales
>> Carlos
>> El mar., 21 may. 2019 a las 3:23, Luigi Pirelli (<luipir en gmail.com>)
>> escribió:
>>> olvidalo... desinstala y añade el repo de alexbruy... y si no sabe como
>>> aladir un repo, hay kilos de guia en la web. NO instalarlo a mano si no
>>> sabes lo que estas haciendo.
>>> Luigi Pirelli
>>> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>>> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>>> * GitHub: https://github.com/luipir
>>> * Mastering QGIS 2nd Edition:
>>> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>>> * Hire me: http://www.qcooperative.net
>>> On Tue, 21 May 2019 at 00:05, carlos h <carloslda256 en gmail.com> wrote:
>>>> no! renombro el zip como  processing_taudem
>>>> Y dejo los archivos dentro de ese zip:
>>>> [image: image.png]
>>>> Gracias
>>>> Carlos
>>>> El lun., 20 may. 2019 a las 16:25, Luigi Pirelli (<luipir en gmail.com>)
>>>> escribió:
>>>>> y te lo instala con el nombre processing-taudem-master ? no me
>>>>> parece... averiguo mañana
>>>>> Luigi Pirelli
>>>>> * Stackexchange:
>>>>> * Hire me: http://goo.gl/BYRQKg
>>>>> On Mon, 20 May 2019 at 22:30, carlos h <carloslda256 en gmail.com> wrote:
>>>>>> Hola Luigi, exactamente, ese fue el que he utilizado, pero no he
>>>>>> podido instalarlo, me da esos errores!
>>>>>> Gracias
>>>>>> Carlos
>>>>>> El lun., 20 may. 2019 a las 15:13, Luigi Pirelli (<luipir en gmail.com>)
>>>>>> escribió:
>>>>>>> porque no lo instalas ponendo el repo de Alex Bruy en la lista de
>>>>>>> los plugin repo en el plugin manager?
>>>>>>> https://plugins.bruy.me/plugins/plugins.xml ?
>>>>>>> Luigi Pirelli
>>>>>>> * Stackexchange:
>>>>>>> On Mon, 20 May 2019 at 21:55, carlos h <carloslda256 en gmail.com>
>>>>>>> wrote:
>>>>>>>> Hola un gusto saludarles, no consigo instalar Taudem para QGIS 3.x,
>>>>>>>> sigo los pasos de aquí:
>>>>>>>> https://gis.stackexchange.com/questions/272797/adding-taudem-provider-to-qgis-3/272814
>>>>>>>> Mas me da los errores de abajo, uso Windows 10, 64 bits, Qgis 3.x
>>>>>>>> (3.6.2, 3.42)
>>>>>>>> Agradezco si alguien puede dar una solución o hacer un video paso a
>>>>>>>> paso, gracias
>>>>>>>> Carlos
>>>>>>>>   File "C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python\qgis\utils.py", line 309, in loadPlugin
>>>>>>>>   File "C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python\qgis\utils.py", line 672, in _import
>>>>>>>> 04:59:51) [MSC v.1914 64 bit (AMD64)]
>>>>>>>> Versión de QGIS: 3.6.2-Noosa Noosa, 656500e0c4
>>>>>>>> Ruta de Python:
>>>>>>>>    - C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python
>>>>>>>>    - C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python/plugins
>>>>>>>>    - C:\PROGRA~1\QGIS3~1.6\bin
>>>>>>>>    - C:\Program Files\QGIS 3.6\bin\python37.zip
>>>>>>>>    - C:\PROGRA~1\QGIS3~1.6\apps\Python37\DLLs
>>>>>>>>    - C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib
>>>>>>>>    - C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages
>>>>>>>>    - C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\win32
>>>>>>>>    C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\win32\lib
>>>>>>>>    C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\Pythonwin
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-es mailing list
>>>>>>>> QGIS-es en lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-es
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20190521/58a4ca78/attachment-0001.html>
Type: image/png
Desc: no disponible
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20190521/58a4ca78/attachment-0001.png>
Más información sobre la lista de distribución QGIS-es
