[QGIS-es] Ayuda
José Carlos Guerrero Antúnez jcgantunez en gmail.com
Sab Ene 2 15:08:47 PST 2021
Hola Pablo,
Lo que ocurre es que este complemento no es compatible con las versiones de
QGIS 3.x, por lo menos en Mac.
Hay varias opciones para agregar un mapa base (Google Maps, OpenStreetMap,
1)
http://students.eagle-science.org/python-script-for-qgis-3-0-basemaps/
2)
https://mappinggis.com/2018/03/como-anadir-mapas-base-en-qgis-3-0-openstreetmap-google-carto-stamen/
3)
Instalar el complemento HCMGIS
Saludos,
El sáb, 2 ene 2021 a las 13:57, Pablo Penagos (<ppenagosr en gmail.com>)
escribió:
> Estoy iniciándome en QGIS  y tengo la v. 3.10 A Coruña, en Mac. Al
> instalar el plugin de Google Earth, da error y este mensaje:
> "Couldn't load plugin 'qgis_gee_data_catalog' due to an error when
> calling its classFactory() method
> ModuleNotFoundError: No module named 'ee'
> Traceback (most recent call last):
>   File "/Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 334, in _startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "/Users/pablopenagosruzo/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qgis_gee_data_catalog/__init__.py", line 33, in classFactory
>     from .qgis_gee_data_catalog import GeeDataCatalog
>   File "/Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 792, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/Users/pablopenagosruzo/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qgis_gee_data_catalog/qgis_gee_data_catalog.py", line 26, in
>     from .ee_interface import (add_ee_image_layer, download_ee_image_layer,
>   File "/Users/pablopenagosruzo/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/qgis_gee_data_catalog/ee_interface.py", line 6, in
>     import ee
> Python version: 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1
> (clang-1001.0.46.3)]
> QGIS version: 3.10.13-A Coruña A Coruña, 311f3bbade
> Python Path:
>    - /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python
>    - /Users/pablopenagosruzo/Library/Application
>    - /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/plugins
>    /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages
>    /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
>    - /Applications/QGIS3.10.app/Contents/Resources/python
>    /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
>    /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
>    Support/QGIS/QGIS3/profiles/default/python”
> Gracias.
> Pablo Penagos Ruzo
> Franz Liszt 652 Urb. Primavera
> Trujillo - Peru
> Cel. +51 984 120
> QGIS-es mailing list
> QGIS-es en lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-es
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20210102/b48776ab/attachment.html>
Más información sobre la lista de distribución QGIS-es
