[QGIS-it-user] Errore processing su Qgis 2.14
girarsi
girarsi a gmail.com
Lun 20 Giu 2016 08:58:18 PDT
Le info da Qgis su Debian Testing/Unstable 64 bit KDE:
Versione di QGIS
2.14.3-Essen
QGIS code branch
Release 2.14
Compilato con Qt
4.8.7
Esecuzione con Qt
4.8.7
Compilato con GDAL/OGR
2.1.0
Esecuzione con GDAL/OGR
2.1.0
Compilato con GEOS
3.5.0-CAPI-1.9.0
Esecuzione con GEOS
3.5.0-CAPI-1.9.0 r4084
Versione client PostgreSQL
9.5.3
Versione SpatiaLite
4.3.0a
Versione QWT
5.2.3
Versione PROJ.4
492
Versione QScintilla2
2.9.2
Questa copia di QGIS scrive messaggi di debug.
Dopo gli ultimi aggiornamenti mi continua a dare questo errore
all'avvio, di cui copioincollo il contenuto:
Impossibile caricare il plugin 'processing'
ImportError: No module named QtWebKit.QWebView
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 281, in
loadPlugin
__import__(packageName)
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 572, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/usr/share/qgis/python/plugins/processing/__init__.py", line 29, in
from processing.tools.general import *
_import
File "/usr/share/qgis/python/plugins/processing/tools/general.py",
line 28, in
from processing.core.Processing import Processing
_import
File "/usr/share/qgis/python/plugins/processing/core/Processing.py",
line 44, in
from processing.gui.Postprocessing import handleAlgorithmResults
_import
File
"/usr/share/qgis/python/plugins/processing/gui/Postprocessing.py", line
39, in
from processing.gui.ResultsDialog import ResultsDialog
_import
File "/usr/share/qgis/python/plugins/processing/gui/ResultsDialog.py",
line 38, in
os.path.join(pluginPath, 'ui', 'DlgResults.ui'))
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/__init__.py", line
211, in loadUiType
exec(code_string.getvalue(), ui_globals)
File "", line 52, in
_import
Versione Python: 2.7.12rc1 (default, Jun 13 2016, 09:20:59) [GCC 5.4.0
20160609]
Versione di QGIS: 2.14.3-Essen Essen, exported
Path di Python:
/home/simone/.qgis2/python
/home/simone/.qgis2/python/plugins
/usr/lib/python2.7
/usr/lib/python2.7/plat-x86_64-linux-gnu
/usr/lib/python2.7/lib-tk
/usr/lib/python2.7/lib-old
/usr/lib/python2.7/lib-dynload
/usr/local/lib/python2.7/dist-packages
/usr/lib/python2.7/dist-packages/PILcompat
/usr/lib/python2.7/dist-packages/gtk-2.0
/home/simone/.qgis2//python
Ho provato a cercare queste QtWebKit, na mi risultano installate con
un'altro nome:
libqtwebkit4:amd64 2.3.4.dfsg-8
libqt5webkit5:amd64 5.5.1+dfsg-2+b1
Posso avere qualche dritta su cosa cercare?
Simone Girardelli
_|_|_|_|_|_|_|_|_|_
|_|_|_|_|_|_|_|_|_|_|
Maggiori informazioni sulla lista
QGIS-it-user
