[QGIS-it-user] Lizmap - errore stampa
Ludovico
ludovicofrate a hotmail.it
Mer 29 Nov 2017 12:55:36 PST
Ciao a tutti. Quando provo a stampare una mappa realizzata tramite lizmap
ottengo il seguente errore:
Error 500. A technical error has occured. Sorry for this trouble.
Questa accade sia con il progetto di default (Montpellier) che con un mio
progetto dove ho impostato la stampa della sola mappa (senza legende,
etichette, testo, ecc..)
Utilizzo QGIS server 2.18 su server ubuntu xenial.
Log di Apache
[Wed Nov 29 20:34:57.090890 2017] [mpm_prefork:notice] [pid 27098] AH00163:
Apache/2.4.18 (Ubuntu) mod_fcgid/2.3.9 configured -- resuming normal
operations
[Wed Nov 29 20:34:57.091010 2017] [core:notice] [pid 27098] AH00094: Command
line: '/usr/sbin/apache2'
Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
variable.
variable.
Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment
variable.
variable.
variable.
ERROR: Auth db directory path could not be created
variable.
variable.
variable.
variable.
variable.
variable.
variable.
variable.
php-apache2handler-165.227.79.18[27105]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":124.01509284973,"CACHE_STATUS":"off"}
php-apache2handler-165.227.79.18[27104]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":11.956930160522,"CACHE_STATUS":"off"}
php-apache2handler-165.227.79.18[27103]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":24.570941925049,"CACHE_STATUS":"off"}
php-apache2handler-165.227.79.18[27165]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":15.614986419678,"CACHE_STATUS":"off"}
php-apache2handler-165.227.79.18[27167]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":14.615058898926,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":24.250984191895,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":12.125015258789,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":13.375997543335,"CACHE_STATUS":"off"}
php-apache2handler-165.227.79.18[27174]:
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":11.543989181519,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":13.32688331604,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":11.248111724854,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":15.501976013184,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":13.952016830444,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":121.79708480835,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":86.496114730835,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":88.958024978638,"CACHE_STATUS":"off"}
{"NAME":"LIZMAP_SERVICE_GETMAP","RESPONSE_TIME":98.987102508545,"CACHE_STATUS":"off"}
Dott. For. Ludovico Frate, PhD
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista
QGIS-it-user
