[QGIS-it-user] zoom su classificazione layer
Totò
pigrecoinfinito a gmail.com
Mar 19 Set 2017 01:51:23 PDT
skampus wrote
> Plug In go2next feature by Enrico ferraguti
Ottimo plugin, ma come dice la descrizione:
This plugin allows to select a layer and jump from a feature to another.
It's possible to select an attribute of the the layer (usually an ID) and
follow it. Press "F8" to go to the next feature. It's possibile to use a PAN
function or a Zoom function(usefull for poligons and lines). The plugin was
created for checking the position of every single feature of a layer without
using the attribute table.
è possibile saltare da una feature all'altra, ma una feature e non un gruppo
di feature.
saluti
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista
QGIS-it-user
