[QGIS-it-user] IMPORTPHOTOS - ERROR - OSX
Tony75
iperstatica a gmail.com
Dom 15 Apr 2018 04:03:42 PDT
Ciao
ho seguito ciò che hai indicato, con la speranza di aver scaricato il
pacchetto giusto. continua a darmi questo errore
➜ ~ pip3 install exifread
Collecting exifread
Downloading ExifRead-2.1.2.tar.gz
Building wheels for collected packages: exifread
Running setup.py bdist_wheel for exifread ... done
Stored in directory:
/Users/Harlock/Library/Caches/pip/wheels/bf/4a/e3/7c17937fac0c09f5a22d5c80021d85ad47befebef193197f11
Successfully built exifread
Installing collected packages: exifread
Successfully installed exifread-2.1.2
You are using pip version 9.0.3, however version 10.0.0 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
*HO AGGIORNATO PIP :*
➜ ~ sudo pip install --upgrade pip
Password:
The directory '/Users/Harlock/Library/Caches/pip/http' or its parent
directory is not owned by the current user and the cache has been disabled.
Please check the permissions and owner of that directory. If executing pip
with sudo, you may want sudo's -H flag.
The directory '/Users/Harlock/Library/Caches/pip' or its parent directory is
not owned by the current user and caching wheels has been disabled. check
the permissions and owner of that directory. If executing pip with sudo, you
Collecting pip
Downloading pip-10.0.0-py2.py3-none-any.whl (1.3MB)
100% |████████████████████████████████| 1.3MB 506kB/s
Installing collected packages: pip
Found existing installation: pip 9.0.3
Uninstalling pip-9.0.3:
Successfully uninstalled pip-9.0.3
Successfully installed pip-10.0.0
➜ ~ sudo pip3 install exifread
sudo: pip3: command not found
*HO PROVATO COSÌ E : *
➜ ~ pip install exifread
Requirement already satisfied: exifread in /Library/Python/2.7/site-packages
(2.1.2)
matplotlib 1.3.1 requires nose, which is not installed.
matplotlib 1.3.1 requires tornado, which is not installed.
zsh: command not found: pip3
CONTINUA A DARMI L'ERRORE :
Impossibile caricare il plugin 'ImportPhotos' a causa di un errore chiamando
il metodo classFactory()
ModuleNotFoundError: No module named 'exifread'
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista
QGIS-it-user
