[QGIS-it-user] QGIS 3 beta - Installazione su macOS
    Tony75
    iperstatica a gmail.com
    Dom 11 Mar 2018 04:27:19 PDT
Ha finito adesso di installare i pacchetti ma niente errore, inserisco anche
il file LOG.
Potresti darmi qualche suggerimento in merito? Grazie
Error: Failed to build qgis3: command execution failed
Error: See
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_macports_release_tarballs_ports_gis_qgis3/qgis3/main.log
for details.
Error: Follow https://guide.macports.org/#project.tickets to report a bug.
Error: Processing of port qgis3 failed
--->  Some of the ports you installed have notes:
  dbus has the following notes:
    # Startup items have been generated that will aid in
    # starting dbus with launchd. They are disabled
    # by default. Execute the following commands to start them,
    # and to cause them to launch at startup:
    # sudo launchctl load -w
    /Library/LaunchDaemons/org.freedesktop.dbus-system.plist
    # launchctl load -w
/Library/LaunchAgents/org.freedesktop.dbus-session.plist
  libpsl has the following notes:
    GTK-based documentation is provided by the port 'libpsl-docs'.
  postgresql10 has the following notes:
    To use the postgresql server, install the postgresql10-server port
  py36-cython has the following notes:
    To make the Python 3.6 version of Cython the one that is run when you
    execute the commands without a version suffix, e.g. 'cython', run:
    port select --set cython cython36
  py36-sip has the following notes:
    py36-sip is available under a PSF license with one addition:
        4. Licensee may not use SIP to generate Python bindings for any C or
           C++ library for which bindings are already provided by Riverbank.
    GPL-2 or GPL-3 licenses are also available. For details see
    /opt/local/share/doc/py36-sip/LICENSE [-GPL2 -GPL3]
  python27 has the following notes:
    To make this the default Python or Python 2 (i.e., the version run by
the
    'python' or 'python2' commands), run one or both of:
        sudo port select --set python python27
        sudo port select --set python2 python27
  python36 has the following notes:
    To make this the default Python or Python 3 (i.e., the version run by
the
    'python' or 'python3' commands), run one or both of:
        sudo port select --set python python36
        sudo port select --set python3 python36
main.log <http://osgeo-org.1560.x6.nabble.com/file/t382845/main.log>
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
       Maggiori informazioni sulla lista
	       QGIS-it-user
