[QGIS-it-user] Problemi installazione tweepy
gabriele.dipalma a uniba.it gabriele.dipalma a uniba.it
Dom 19 Apr 2020 07:31:55 PDT
Buongiorno a tutti,
per favore avrei bisogno di installare qweetgis. Per farlo occorre
prima installare tweepy, una library python. Per favore c'è qualcuno
che mi sa spiegare perché QGIS, all'apertura, mi dice:  "Could not
import tweepy, install tweepy to use the plugin". Di seguito i
dettagli dell'errore.
Utilizzo 3.12.0-București su un Mac OS Catalina.
Grazie mille,
Gabriele
Impossibile caricare il plugin 'qweetgis' a causa di un errore
chiamando il metodo classFactory()
ModuleNotFoundError: No module named 'tweepy'
   File
"/Applications/QGIS3.12.app/Contents/MacOS/../Resources/python/qgis/utils.py",
line 334, in _startPlugin
     plugins[packageName] = package.classFactory(iface)
   File "/Users/alekseyvoda/Library/Application
Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/__init__.py", line
35, in classFactory
     from .search.main import ThreadingMaster
   File
line 744, in _import
     mod = _builtin_import(name, globals, locals, fromlist, level)
Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/search/main.py",
line 48, in
     from ..authentication.credentials_validator import CredentialsValidator
   File
Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/authentication/credentials_validator.py", line 3,
in
     from ..authentication.mod_tweepy import TestTweetsAuthHandler
   File
Support/QGIS/QGIS3/profiles/default/python/plugins/qweetgis/authentication/mod_tweepy.py", line 3,
in
     import tweepy
   File
Versione Python: 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1
(clang-1001.0.46.3)]
Versione di QGIS: 3.12.0-București București, 409bcf8eaa
Percorso Python:
/Applications/QGIS3.12.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
/Applications/QGIS3.12.app/Contents/Resources/python
/Applications/QGIS3.12.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
Maggiori informazioni sulla lista QGIS-it-user
