[QGIS-it-user] R: R: qgis server + lizmap con HTTPS
nadiaspit nadia.spitilli a gmail.com
Mar 7 Gen 2020 09:38:48 PST
Si, avevo abilitato fcgi.
Nonostante gli errori, andando avanti con l'installazione, ottengo risposta
alla GetCapabilities
<http://osgeo-org.1560.x6.nabble.com/file/t385858/Annotation_2020-01-07_183343.jpg>
Questo è il log di qgis:
18:32:44 INFO Server[10529]: Qgis Server Settings:
18:32:44 INFO Server[10529]:   - QGIS_OPTIONS_PATH / '' (Override the
default path for user configuration): '' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_PARALLEL_RENDERING /
'/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
getMap request): 'false' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_MAX_THREADS /
'/qgis/max_threads' (Number of threads to use when parallel rendering is
activated): '-1' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_LOG_LEVEL / '' (Log level): '0'
(read from ENVIRONMENT_VARIABLE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_LOG_FILE / '' (Log file):
'/var/log/qgis/qgisserver.log' (read from ENVIRONMENT_VARIABLE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_LOG_STDERR / ''
(Activate/Deactivate logging to stderr): 'false' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_PROJECT_FILE / '' (QGIS project file):
18:32:44 INFO Server[10529]:   - MAX_CACHE_LAYERS / '' (Specify the maximum
number of cached layers): '100' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_CACHE_DIRECTORY /
'/cache/directory' (Specify the cache directory):
'//.local/share/QGIS/QGIS3/profiles/default/cache' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size'
(Specify the cache size): '52428800' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
'/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
18:32:44 INFO Server[10529]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
'/locale/userLocale' (Override system locale): '' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_WMS_MAX_HEIGHT /
'/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of
this and the project configuration is used.): '-1' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_WMS_MAX_WIDTH /
'/qgis/max_wms_width' (Maximum width for a WMS request. The most
conservative between this and the project one is used): '-1' (read from
DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY /
'/qgis/server_api_resources_directory' (Base directory where HTML templates
and static assets (e.g. images, js and css files) are searched for):
'/usr/share/qgis/resources/server/api' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT /
'/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features
request, defaults to 10000): '10000' (read from DEFAULT_VALUE)
18:32:44 INFO Server[10529]: Ini file used to initialize settings:
/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
18:32:44 INFO Server[10529]: cacheDirectory:
/.local/share/QGIS/QGIS3/profiles/default/cache/
18:32:44 INFO Server[10529]: maximumCacheSize: 52428800
18:32:44 INFO Server[10529]: Prefix  PATH: /usr
18:32:44 INFO Server[10529]: Plugin  PATH: /usr/lib/qgis/plugins
18:32:44 INFO Server[10529]: PkgData PATH: /usr/share/qgis
18:32:44 INFO Server[10529]: User DB PATH:
//.local/share/QGIS/QGIS3/profiles/default/qgis.db
18:32:44 INFO Server[10529]: Auth DB PATH:
/home/qgis/qgisserverdb/qgis-auth.db
18:32:44 INFO Server[10529]: SVG PATHS:
/usr/share/qgis/svg/://.local/share/QGIS/QGIS3/profiles/default/svg/
Nonostante gli errori iniziali si può concludere che qgis-server funziona
correttamente?
Grazie
N.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista QGIS-it-user
