[QGIS-it-user] [Qgis-user] Udate QGIS 3.26.0
Leonardo Donnini ldonnini a bonibit.com
Lun 4 Lug 2022 00:31:54 PDT
Hi  Andrea,
after manually installed the Microsoft Visual C++ Redistributable
Package (Visual Studio 2015, 2017, 2019 e 2022) the error message
loading QGIS was changed in :
/Could not load qgis_App.dll
Windows error: runtime di inizializzazione della libreria di
collegamento dinamico (DLL) non riuscita./
/Chek C:\OSGeo4W\bin\qgis-bin.env for correct enviroment path/
are there others suggestion ?
Thanks
Leonardo
Il 30/06/2022 11:39, Andrea Giudiceandrea ha scritto:
> *Leonardo Donnini*ldonnini at bonibit.com
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Udate%20QGIS%203.26.0&In-Reply-To=%3C540a559d-4f12-0f0f-8d76-ccc8fb60df74%40bonibit.com%3E>
>>>> /Wed Jun 29 04:15:41 PDT 2022/
>>>> update to 3.26.0 failed :
>>>> VCRUNTIME140_1.dll not found
> Hi Leonardo,
> I've never seen such issue and it seems to me it was never previously
> reported in https://github.com/qgis/QGIS/issues nor in
> https://trac.osgeo.org/osgeo4w/.
> This issue is specific to the OSGeo4W installation, so it would be
> very useful if you could create a new detailed ticket in
> The VCRUNTIME140_1.dll is part of the Microsoft Visual C++
> Redistributable Package and usually it is installed by the OSGeo4W
> installer if missing (the "msvcrt2019" package).
> As a workaround I think you can try to manually install the Microsoft
> Visual C++ Redistributable Package (Visual Studio 2015, 2017, 2019 e
> 2022) from
> https://support.microsoft.com/help/2977003/the-latest-supported-visual-c-downloads
> (I think both x86 and x64 are needed).
> Best regards.
> Andrea
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20220704/158cfb52/attachment.htm>
Maggiori informazioni sulla lista QGIS-it-user
