[Qgis-psc] svn access for Richard Duivenvoorde
    Gary Sherman
    sherman at mrcc.com
    Thu Apr 10 07:44:16 PDT 2008
In the course of going thorough incubation for OSGeo, we added a
requirement that contributors publicly agree to abide by the developer
guidelines by sending an email to the qgis-developer list.
These guidelines are found at: http://wiki.qgis.org/qgiswiki/ContributorGuidelines
Just to make sure everybody understands the requirements and
responsibilities, I'm going to ask all developers and contributors to
send an email to the list.
+1 for Richard, providing he indicates agreement via email to the list.
-gary
On Apr 9, 2008, at 8:57 AM, Marco Hugentobler wrote:
> Hi Gary, Otto, Paolo, Tim
> Richard is an active community member, in the release team and now as
> maintainer of the srs database (srs.db). I therefore like to ask
> your opinion
> about giving him svn write access.
> My opinion is +1
> Regards,
> Marco
> ----------  Weitergeleitete Nachricht  ----------
> Betreff: Re: AW: AW: [Qgis-user] why is EPSG:2180 not recognised?
> Datum: Mittwoch 09 April 2008
> Von: Richard Duivenvoorde <rdmailings at duif.net>
> An: Hugentobler Marco <marco.hugentobler at karto.baug.ethz.ch>
> Hi Marco,
> ack.
> I will sent you a new srs.db in the upcoming days. Or is it possible
> for
> me to get an svn-account (usefull for dutch translation also)? I'm
> comfortable with svn already....
> Thanks,
> Hugentobler Marco wrote:
>> Hi Richard,
>> Thanks for offering your help. Afaik (projection gurus, please
>> correct me
> where I'm wrong) your understanding is right and it's all about
> updating the
> srs.db with sqliteadmin. I think updating is not necessary before a
> release,
> it can be done whenever you hear about epsg updates or people tell
> you about
> a bug.
>> So I'm going to add you as maintainer of srs.db to the wiki and
>> will direct
> people with projection updates to you. I'm not an expert concerning
> projection specific questions (only one common coordinate system in
> Switzerland :-) ). If you have any questions, just send a mail to
> the user
> and developer list. I think there are a lot of people in the QGIS
> community
> with profound knowledge of projections and spatial reference systems.
>> cheers,
>> Marco
>> -----Ursprüngliche Nachricht-----
>> Von: Richard Duivenvoorde [mailto:rdmailings at duif.net]
>> Gesendet: Mo 07.04.2008 20:49
>> Cc: Jean-Claude Repetto; qgis-user at lists.osgeo.org; tutey at o2.pl;
> tim at linfiniti.com
>> Betreff: Re: AW: [Qgis-user] why is EPSG:2180 not recognised?
>> Hi,
>> I've got sqliteadmin (http://sqliteadmin.orbmu2k.de/) here, and it
>> seems
>> pretty trivial to update the database srs.db with that tool...
>> Though it might not be that trivial?
>> Looking at a freshly downloaded epsg file of the proj lib, I see
>> # WGS 72
>> <4322> +proj=longlat +ellps=WGS72 +no_defs  <>
>> The same holds true for 4322, 4622 and 4625
>> Can somebody explain to me then why it should be jean-claude's
>> version?
>> Or in other words, if the latest proj doesn't have it, what/who
>> should
>> be the authorative source in this case then?
>> The srs.db. is nothing more then the parameters used by proj isn't
>> it?
>> Or am I missing something here?
>> 3328 - 3335 are indeed available in latest proj (and not in
>> srs.db), so
>> it should be easy to add them.
>> same for 3120
>> same for 3066
>> If I can count on some help with projection-specific questions, I can
>> make it a part of my 'release-team' work? I will add it to the
>> release-checklist in wiki then.
>> Is it ok to update it for every release, or for every 'bug' people
>> find
>> in it?
>> Regards,
>>> Hi Maciej, Jean-Claude
>>>> Please don't tell me that I can send a patch with updates for the
>>>> CS
>>>> database. That would fix only my problem, while EPSG database has
>>>> lots
>>>> of fixes and additions in each new version, which get included in
>>>> new
>>>> releases of PROJ, GDAL, GRASS but not in QGIS.
>>> It is of course also possible that you update the other entries in
>>> the
> sqlite database of qgis.
>>> Ideal would be a volunteer that acts as a maintainer of srs.db and
>>> updates
> it in regular periods.
>>> Regards,
>>> Marco
>>> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Jean-Claude
>>> Repetto
>>> Gesendet: Mo 07.04.2008 10:09
>>> An: qgis-user at lists.osgeo.org
>>> Betreff: Re: [Qgis-user] why is EPSG:2180 not recognised?
>>> Maciej Sieczka wrote :
>>>> QGIS CS database is severly outdated.
>>> Hello,
>>> I agree.
>>> Other examples :
>>> WGS72 (EPSG 4322)
>>> The QGIS database contains :
>>> It should be :
>>> +proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.219 +no_defs
>>> (look at <http://proj.maptools.org/gen_parms.html#towgs84>)
>>> Guadeloupe 1948 (EPSG 4622)
>>> +proj=longlat +ellps=intl +no_defs
>>> It should be :
>>> +towgs84=-472.29,-5.63,-304.12,0.4362,-0.8374,0.2563,1.8984 +no_defs
>>> Martinique 1938 (EPSG 4625)
>>> +proj=longlat +ellps=intl +no_defs  <>
>>> It should be :
>>> +towgs84=126.93,547.94,130.41,-2.7867,5.1612,-0.8584,13.8227
>>> +no_defs
>>> Conclusion : Don't trust the EPSG database, allways check the
>>> parameters.
>>> Jean-Claude
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> Technical Advisor QGIS Project Steering Committee
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
-Desktop GIS Book:
   *http://desktopgisbook.com
"We work virtually everywhere"
More information about the Qgis-psc
