[Fwd: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle raster plugin]]]
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Wed Apr 15 07:22:26 PDT 2009
Ok, it is in trunk now.
Thanks to Ivan for providing the code and to Tim for being liberal with the
feature freeze deadline.
Btw, I changed the plugin folder to 'oracle_raster' and plugin title to
'Oracle Spatial GeoRaster' to not confuse people that use oracle spatial
vector features.
cheers,
Marco
Am Mittwoch 15 April 2009 11:38:19 schrieb Tim Sutton:
> Hi
> On Wed, Apr 15, 2009 at 8:43 AM, Marco Hugentobler
> <marco.hugentobler at karto.baug.ethz.ch> wrote:
> > Hi
> > I had a quick look at the patch this morning.
> > The patch seems ok to me and if there are no further objections, I'm
> > going to apply it to trunk.
> > However, in the longer term it would probably be good to have a unified
> > loading dialog for rasters where file based and database GDAL datasources
> > can be selected (similar to the vector ogr loading dialog). Tim, what is
> > your opinion about this?
> Yes this is absolutely where we should head towards. Also to allow
> rasters with multiple subsets like hdf4:eos and hdf5:eos. I see there
> is already a plugin for hdf4:eos in the repo.
> +1 for you to commit this for the 'Pan' release.
> Please note I will probably be out of contact for the next two days or so.
> Regards
> Tim
> > Regards,
> > Marco
> > Am Dienstag 14 April 2009 19:05:04 schrieb Paolo Cavallini:
> >> Hi all.
> >> I'm forwarding the patch, but I also suggested Ivan to send it to the
> >> -dev ML.
> >> All the best.
> >> -------- Messaggio Originale  --------
> >> Oggetto: Re: [Fwd: Re: [Qgis-psc] [Fwd: Re: [Qgis-developer] oracle
> >> raster plugin]]
> >> Data: Tue, 14 Apr 2009 07:09:11 -0400
> >> Da: Ivan Lucena <ivan.lucena at pmldnet.com>
> >> >> I am using the plugin all the time now because it helped me to find a
> >> >> bug in GDAL when loading a raster with pyramids. So right now I am
> >> >> working on my code in GDAL/GeoRaster and I will send the patch after
> >> >> that.
> >> > You can submit a bugfix later, but it's important that it goes in
> >> > before feature freeze.
> >> The bug that I am working on is on GDAL GeoRaster driver source code.
> >> The plugin itself is working fine.
> >> >> Thanks a lot,
> >> > Thanks to you, rather!
> >> There is PNG icon that is not included on the diff file and I don't know
> >> how I would send it other
> >> than by a attachment on a e-mail.
> >> My best regards,
> >> Ivan
> > Dr. Marco Hugentobler
> > Institute of Cartography
> > ETH Zurich
> > Technical Advisor QGIS Project Steering Committee
ETH Zurich
More information about the Qgis-psc mailing list
