[Qgis-psc] Release Name - Was: [Qgis-developer] Reminder: Freeze starts on 2014-01-24 (4 days)
Matthias Kuhn
matthias.kuhn at gmx.ch
Thu Mar 27 02:35:21 PDT 2014
Chamonix starts with C as well
On Thu 27 Mar 2014 10:25:34 AM CET, Andreas Neumann wrote:
> And to make things easier you could pick a name in any language - so
> either "Köln" or "Cologne" - both would work ;-)
>> Some ideas from our discussion during breakfast here on HF in Vienna.
>> To get versions order into the code name, we could use the same
>> alphabetical schema as Android [1]. Brighton is the good starting
>> point. We will regularly return to Essen so we can use it later. That
>> means that the next HF location should start with "C".
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc
