[Qgis-psc] Release Name - Was: [Qgis-developer] Reminder: Freeze starts on 2014-01-24 (4 days)
    Radim Blazek
    radim.blazek at gmail.com
    Thu May 15 00:40:49 PDT 2014
On Thu, Mar 27, 2014 at 3:56 PM, Gary Sherman <gsherman at geoapt.com> wrote:
> So does Chugiak :)
Chugiak sounds great! The 2.4 is a good moment to honour Gary, Alaska
and its long winter nights who gave us QGIS.
Radim
> https://goo.gl/maps/2KIyS
> -gary
>> On Thu 27 Mar 2014 10:25:34 AM CET, Andreas Neumann wrote:
>>> And to make things easier you could pick a name in any language - so
>>> either "Köln" or "Cologne" - both would work ;-)
>>>> Some ideas from our discussion during breakfast here on HF in Vienna.
>>>> To get versions order into the code name, we could use the same
>>>> alphabetical schema as Android [1]. Brighton is the good starting
>>>> point. We will regularly return to Essen so we can use it later. That
>>>> means that the next HF location should start with "C".
>>> Qgis-psc mailing list
>>> Qgis-psc at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-psc
> Gary Sherman
> Founder, QGIS Project
> Consulting: geoapt.com
> Publishing: locatepress.com
> We work virtually anywhere
More information about the Qgis-psc
