[Qgis-psc] Proposal that QGIS.ORG will become a member of the OpenDesign Alliance
    Andreas Neumann
    a.neumann at carto.net
    Tue Dec 15 08:42:24 PST 2015
Hi Strk,
If there would be a good GPL based DWG library I would happily propose
to use it - but unfortunately there isn't. The only partially viable
alternative is the LibreDWG library
(https://www.gnu.org/software/libredwg/) which hasn't received an update
since 2009. Investing in that solution would probably mean an investment
of a medium six-figure amount in Euros and then more to keep it alive.
Unfortunately, unless a viable sponsor comes in, this isn't a solution.
Do you know other alternatives?
About the license: it would be the plan to develop a separate (non GPL)
app/service that uses Teigha. A QGIS CAD Plugin can then connect to this
service and get access to that CAD data. Jürgen has thought about that.
As such, it wouldn't be an integral part of QGIS and QGIS can be
distributed with or without the Teigha library.
Andreas
On 15.12.2015 17:30, Sandro Santilli wrote:
> On Tue, Dec 15, 2015 at 05:05:34PM +0100, Andreas Neumann wrote:
>> Hi Martin,
>> The use and distribution of the Teigha library is really restricted
>> to the organization that is a member. It would probably mean that
>> QGIS.ORG would have to provide the binaries of those versions that
>> should include CAD import support.
> This would mean distributing QGIS with a different license too.
> All Copyright holders should agree about that, right ?
> To me, both QGIS and OSGEO should campaign against proprietary
> formats rather than pushing proprietary code to users.
> --strk;
More information about the Qgis-psc
