[Qgis-psc] Proposal that QGIS.ORG will become a member of the OpenDesign Alliance
Nyall Dawson
nyall.dawson at gmail.com
Tue Dec 15 13:28:26 PST 2015
On 16 December 2015 at 08:04, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Can we put this in ogr/gdal.
> 1) gives us another project to spread the cost over
> 2) they already do this for other drivers
> 3) others will get it for free if its built at a ogr level
Great idea. This would also have the benefit of exposing it via the
ogr command line tools and all the other projects which use these (eg
PostGIS FD wrappers!).
Nyall
> I guess someone still needs to pay for it but at least if solves the GPL
> issue.
> On Wed, 16 Dec 2015 6:56 am Andreas Neumann <a.neumann at carto.net> wrote:
>> Vincent et all.
>> Here is another issue I found out while doing research on LibreDWG. It
>> is not so much a funding issue, but more a GPL v2 vs. v3 incompatibility
>> issue.
>> Apparently you are not allowed to mix GPLv2 and v3. LibreDWG is v3. Most
>> other graphics software is v2.
>> For that reason, OpenSource CAD or graphics projects like FreeCAD,
>> LibreCAD, Inkscape, Blender, etc. are not allowed to use LibreDWG.
>> Not so sure about the situation of QGIS. QGIS states it is GPLv2 or
>> above. What does it mean? Is it v2 or v3 or both?
>> See
>> http://libregraphicsworld.org/blog/entry/libredwg-drama-the-end-or-the-new-beginning
>> Seems like Richard Stallman personally stated that he is not going to
>> solve this GPL licensing compatibility issue. Apparently, LibreDWG was
>> forked by the project LibDWG, which is now developed under GPL v2 - but
>> also not very mature and stable. Last commit from March 2015.
>> Anyway - I feel very uncomfortable building on an unfinished and not
>> very actively developed library that no other project really uses in a
>> professional project.
>> Andreas
>> On 15.12.2015 20:00, Vincent Picavet (ml) wrote:
>> > Hello,
>> > On 15/12/2015 15:37, Andreas Neumann wrote:
>> >> Hi QGIS.ORG board,
>> >> As you may be aware, Jürgen I worked on a proposal to allow import of
>> >> CAD data into QGIS. Jürgen provided an offer.
>> >> We plan to use the Teigha library of the OpenDesign Alliance (ODA)
>> >> (https://www.opendesign.com/the_oda_platform/Teigha). It isn't GPL
>> >> compatible and it requires a membership fee with annual renewal.
>> >> I was investigating whether OSGEO could become a member - this is
>> >> theoretically possible, but it would require a higher and more
>> >> expensive
>> >> membership level than as if QGIS.ORG would become a member. I would
>> >> thus
>> >> propose that QGIS.ORG becomes a sustaining member of the ODA, which
>> >> would allow to distribute binaries of the Teigha library for all of our
>> >> supported platforms, along with the QGIS binaries.
>> >> Financially, the sustaining membership level would mean US $5000.- in
>> >> the first year and US $3000.- annual renewal in the subsequent years. I
>> >> would propose that QGIS.ORG would pay this membership fees from the
>> >> QGIS.ORG funds - and if you agree - will include it into our 2016
>> >> budget. See https://www.opendesign.com/Sustaining
>> > I am really wondering where we are going to right now with QGIS.Org.
>> > I already gave my opinion that the organization should not spend money
>> > to fund features. This is just an opinion, and I do respect that some
>> > would not agree. It would at least need a debate first though.
>> > But this yet is another story. Funding directly some proprietary
>> > software vendors ? Yearly ? Really ?
>> > I have no problem with QGIS plugins using some prorietary piece of code,
>> > circumventing the GPL. But this proposal is a different beast :
>> > * It is feature-related funding, for a quite large amount ( that's ok if
>> > it is not qgis.org paying, but this should be clear)
>> > * It would fund a proprietary software vendor ( definitly not ok)
>> > * It would package proprietary software with default QGIS releases ( not
>> > ok )
>> > * It would implement a technical (ugly) workaround for licence
>> > compatibility ( not ok in core or default installed plugin )
>> > * It is a recurrent spending, with a very difficult way back ( removing
>> > the user such a feature will be hard)
>> > Why don't you implement a separate proprietary tool with a end-user
>> > installer, having nothing to do with QGIS.org, OSGeo, nor QGIS
>> > distribution, that allows format conversion to QGIS project/data/style
>> > files ?
>> > We would not have to mess with proprietary software, and any
>> > non-opensource organization could pay the money to be allowed to
>> > distribute it. Even a simple end user could distribute this separate
>> > tool, paying the licence fee.
>> > But please, do not involve QGIS.org in this mess, we have plenty enough
>> > with the ECW opensource-not-libre dragon.
>> > Or follow strk's advice and improve the libredwg library. That's the
>> > right way to do things.
>> > Regards,
>> > Vincent
>> > PS : Jeff will probably not answer your queries as he resigned from
>> > OSGeo's board
>> >> I will propose to make this decision dependent on our ability to raise
>> >> the 32k Euros required to pay Jürgen for the QGIS-side development. So
>> >> far I only have confirmations for about 10k Euros. Still some work to
>> >> raise the full amount.
>> >> Do you have any questions regarding this proposal?
>> >> Thanks,
>> >> Andreas
>> >> _______________________________________________
>> >> Qgis-psc mailing list
>> >> Qgis-psc at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc
