[Qgis-psc] Proposal that QGIS.ORG will become a member of the OpenDesign Alliance
Andreas Neumann a.neumann at carto.net
Tue Dec 15 23:15:18 PST 2015
Thank you Jürgen.
If it would be limited to OGR feature styling, than it is not good
enough for our project. That would be a problem.
We would probably also have to enable curve support in the OGR DWG
driver, that uses Teigha.
The other problem with GDAL/OGR: as far as I know, GDAL/OGR doesn't have
a legal entity. It would have to be OSGEO then - which would be several
times more expensive than if QGIS.ORG would be a member, if OSGEO wants
to make it available for all OSGEO projects.
Andreas
On 15.12.2015 23:56, Jürgen E. Fischer wrote:
> Hi Nathan,
> On Tue, 15. Dec 2015 at 21:04:15 +0000, Nathan Woodrow wrote:
>> Can we put this in ogr/gdal.
> There is already DWG support in OGR using Teigha - but apparently no one has
> the library available there either to actually build it - at least not for
> making it public.
> But it's tied to OGR feature model - the features are mapped to simple features
> and it's also tied to it's symbology model - which AFAIK is neither close to
> QGIS symbology possibilities nor to what DXF/DWG can do.  That's probably also
> why the DXF export was implemented natively in QGIS after the symbology support
> in OGR was extented for it.
> So the idea is to make a provider/plugin where you can get most of the DWG and
> have if look close like what it used to look in CAD.
> Jürgen
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20151216/dbe5cdab/attachment.html>
More information about the Qgis-psc mailing list
