[Qgis-psc] Fw: work on the QGIS User Manual 2.8
Otto Dassau
dassau at gbd-consult.de
Fri May 22 02:16:14 PDT 2015
here is a list of topics, Larissa worked on for the 2.8 manual, if we want to
publish that as well.
Regards,
Otto
Beginn der weitergeleiteten Nachricht:
Datum: Fri, 22 May 2015 11:12:00 +0200
Von: Larissa Junek <junek at gbd-consult.de>
An: Otto Dassau <dassau at gbd-consult.de>
Betreff: work on the QGIS User Manual 2.8
Hi Otto,
I worked on the following topics:
- chapter What's new in QGIS 2.8: filter legend items on map content,
grids in composer, …
- chapter Features
- chapter Getting started
- chapter QGIS GUI: add temporary layer, differences between QGIS KDE
and GNOME
- chapter Working with OGC data: Add Describe Layer Method to WMS,
Apache configuration, note about increasing headers size when working
with large features
- processing providers and algorithms: description files
- QGIS behaviour on copy string attribute to another
- tip about default styles in postgresql
- extended Spatial Query Plugin explanations
- better documentation about the priority functionality for labels
- improved documentation for interpolation plugin
- improved documentation for Raster Terrain Analysis plugin
- description of the new GUI of the Identify Tool
- adapted text in chapter Field Calculator
- checked chapter QGIS Configuration
- checked if screenshots need an update
Regards,
Larissa
More information about the Qgis-psc
