[Qgis-psc] Draft announcement re 3.0
    Neumann, Andreas
    a.neumann at carto.net
    Mon Feb  8 02:21:56 PST 2016
yes - Matthias has a plan on an intermediate transition release 2.16.
Specifically, he plans to work on:
 	* Continuous integration (Travis) - tests for both "Python2/PyQT4" as
well as "Python 3/PyQT5".
 	* Introduction of a compatibility layer that allows plugin authors to
support both Python 2 and Python 3 from the same plugin code
 	* Plugin migration tool - extension of the 2to3 Python upgrade tool
with QGIS-specific "fixers" (extensions)
 	* Updates of plugin manager, Python console, Python unit tests and
processing to support both Python 2 and Python 3
His enhancements should be first introcuded in the 2x code base and will
allow plugin authors to start supporting both Python 2 and Python 3 in
the 2x branch, and then later in the 3x branch.
It is therefore useful to start the 3.0 branch after 2.16.
In addition there is a lot of short-term polishing work planned in the
2x branchs (relations, transactions, forms, attribute-table, multi-edit,
DXF, etc.). Branching now would result in extra/unneccesary porting work
between the two branches. This is another reason why Matthias/Nyall
suggested to branch after 2.16.
Matthias is on holidays this week and probably can't answer - that's why
I answer on his behalf.
Andreas
On 2016-02-08 10:47, Tim Sutton wrote:
> Hi
> On Mon, Feb 8, 2016 at 11:45 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> IMO we should just branch now if we are doing it this way.  The sooner the better as it will give us more time to prep.
> Yes except I think Matthias wanted the 2.16 release (with its wrappers etc.) to for the basis for 3.0. If that isnt important then no problem from me to branch now already.
> Regards
> Tim
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/8055ac7e/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/8055ac7e/attachment.gif>
More information about the Qgis-psc
