[Qgis-psc] Draft announcement re 3.0
Matthias Kuhn - OPENGIS.ch matthias at opengis.ch
Tue Feb 9 15:15:43 PST 2016
Or to say it differently: doesn't the term "swap around branches" apply much more to the original proposal which proposes "replacing" - in git terms "force push"?
On February 10, 2016 12:11:33 AM GMT+01:00, "Matthias Kuhn - OPENGIS.ch" <matthias at opengis.ch> wrote:
>Good point
>But doesn't the same apply to the switch at the end of the 3.0
>development in an even worse way because we have the master branch
>replaced with an unmergeable substitute?
>Best
>Matthias
>On February 9, 2016 11:20:50 PM GMT+01:00, Tim Sutton <tim at kartoza.com>
>wrote:
>>Hi
>>> On 10 Feb 2016, at 00:15, Matthias Kuhn - OPENGIS.ch
>>> Hi PSC,
>>> Thank you very much for taking a decision, that will help very much
>>to get ahead!
>>> Just one question, did you evaluate to switch master with a qgis2
>>branch and qgis3 with master? So basically the same schema but with
>>renamed branches.
>>> IMHO that would make it clearer that devs are encouraged to work on
>>qgis 3 and we would not have to "replace" a branch but instead just
>>retire the qgis2 branch once the release happened.
>>I think the problem with that is that there are a lot of downstream
>>build activities that would break straight away if we swap branches
>>around, whilst the intent is to keep master in a stable, packageable
>>state while work goes on in the 3.0. branch.
>>Regards
>>Tim
>>> Thanks again and best wishes
>>> Matthias
>>> On February 9, 2016 11:30:28 AM GMT+01:00, Tim Sutton
>><tim at kartoza.com> wrote:
>>> >Hi
>>> >On Tue, Feb 9, 2016 at 2:58 AM, Larry Shaffer
>><larrys at dakotacarto.com>
>>> >wrote:
>>> >> Hi Tim, Jürgen and PSC,
>>> >> After reviewing this plan I have to say it is an excellent
>>solution
>>> >to a
>>> >> no-size-fits-all problem. Thank you for all the consideration and
>>> >work you
>>> >> have put into it.
>>> >> I now have a solid (and indeterminate :^) schedule to present to
>>my
>>> >> employer, which will help them plan resources to fund further
>QGIS
>>> >> development.
>>> >> It will also help with planning on how/when to produce new
>>nightlies
>>> >for
>>> >> Mac.
>>> >​Thanks Larry - I will post my blog post summarising everything
>>tonight
>>> >(including salient bits from the above discussion). Yes its
>>> >interterminate,
>>> >but I think the general aim is still to try to encourage everyone
>to
>>> >get it
>>> >ready for 1 year from now (as much as we can).
>>> >Regards
>>> >Tim​
>>> >> Regards,
>>> >> Larry Shaffer
>>> >> QGIS Support/Development | Boundless
>>> >> Dakota Cartography
>>> >> Black Hills, South Dakota
>>> >> On Mon, Feb 8, 2016 at 7:45 AM, Jürgen E. <jef at norbit.de> wrote:
>>> >>> Hi Tim,
>>> >>> On Mon, 08. Feb 2016 at 14:01:12 +0200, Tim Sutton wrote:
>>> >>> > Thanks Andreas - I’ll just paraphrase the above as another
>note
>>in
>>> >the
>>> >>> > article - should make things a bit clearer!
>>> >>> Yes. We do 2.16 with PyQt5/Python3 support next to the existing
>>> >>> Qt4/PyQt4/Python2 and the existing and widely unused Qt5
>support.
>>> >So we
>>> >>> have
>>> >>> all the smooth, non-breaking steps in master. We'll still
>release
>>> >using
>>> >>> Qt4/PyQt4/Python2, so that all the plugins keep working. And
>>people
>>> >can
>>> >>> complete stuff that they have already started working on.
>>> >>> 2.16 will be in the regular 4 months schedule.
>>> >>> After 2.16 we branch off a qgis3 branch that gets the API
>>changes.
>>> >There
>>> >>> we
>>> >>> drop Qt4/PyQt4/Python2 support and switch to Qt5/PyQt5/Python3.
>>> >Because
>>> >>> we
>>> >>> cannot really estimate if that takes 4, 8 or even more months,
>>we'll
>>> >work
>>> >>> on
>>> >>> that on a "release when ready" scheme an see how it goes and set
>>a
>>> >date
>>> >>> when
>>> >>> qgis3 stabilized.
>>> >>> The qgis3 branch will be in development so at first we'll
>>probably
>>> >have
>>> >>> something that doesn't build at all, requires dependencies that
>>are
>>> >not
>>> >>> easy
>>> >>> available or at least not available on all platforms, while
>we're
>>at
>>> >it.
>>> >>> Because there might be stuff, that can't wait that long, we
>>> >meanwhile keep
>>> >>> master open for new features. The nightlies can keep on going
>>> >without
>>> >>> much
>>> >>> effort and also regular releases could be done if necessary.
>>> >>> But master should still considered a dead branch as we is relies
>>on
>>> >fading
>>> >>> dependencies and it will be eventually be replaced by the qgis3
>>(no
>>> >>> merge). So
>>> >>> stuff added to master before will get lost, if it was not also
>>> >merged or
>>> >>> redone
>>> >>> for qgis3. So people should think twice if they consider to do
>>> >anything
>>> >>> in
>>> >>> master while we're at qgis3.
>>> >>> Jürgen
>>> >>> Jürgen E. Fischer norBIT GmbH Tel.
>>> >>> +49-4931-918175-31
>>> >>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> >>> +49-4931-918175-50
>>> >>> Software Engineer D-26506 Norden
>>> >>> http://www.norbit.de <http://www.norbit.de/>
>>> >>> QGIS release manager (PSC) Germany IRC: jef on
>>> >>> FreeNode
>>> >>> _______________________________________________
>>> >>> Qgis-psc mailing list
>>> >>> Qgis-psc at lists.osgeo.org
>>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-psc
>><http://lists.osgeo.org/mailman/listinfo/qgis-psc>
>>> >Tim Sutton
>>> >Visit http://kartoza.com <http://kartoza.com/> to find out about
>>open source:
>>> > * Desktop GIS programming services
>>> > * Geospatial web development
>>> >* GIS Training
>>> >* Consulting Services
>>> >Skype: timlinux Irc: timlinux on #qgis at freenode.net
>><http://freenode.net/>
>>> >Tim is a member of the QGIS Project Steering Committee
>>> >Kartoza is a merger between Linfiniti and Afrispatial
>>> Sent from my Android device with K-9 Mail. Please excuse my brevity.
>>Tim Sutton
>>Visit http://kartoza.com <http://kartoza.com/> to find out about open
>>source:
>>* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160210/f50f293e/attachment.html>
More information about the Qgis-psc mailing list
