[Qgis-psc] Fwd: No QGIS in stretch due to Qt4 WebKit removal
Matthias Kuhn
matthias at opengis.ch
Mon Jan 11 07:58:46 PST 2016
On 01/11/2016 04:14 PM, Andreas Neumann wrote:
> Hi,
> On 11.01.2016 15:44, Paolo Cavallini wrote:
>> Il 11/01/2016 14:35, Alexander Bruy ha scritto:
>>> Hi Richard,
>>> QWebView also used by Processing for displaying help and maybe also
>>> by QGIS help system too.
>> AFAIU now in Debian we have qscintilla2 also for Python2, so the plans
>> are to compile QGIS with Qt5+Py2. Therefore, the main issue for Debian
>> testing/sid users will be webkit. Considering that 2.14 is an LTR, and
>> we plan to extend its duration to 2 years, wouldn't it be feasible to
>> try and reduce the problem, at least for Processing, replacing webkit
>> with something else?
>> Thanks a lot.
> hm - I (and probably others) use the HTML widget in the print composer
> quite a lot. It is the only way to have richer content in print
> composer. Not a good move to just compile without Webkit and there is
> no good replacement. It would cause me troubles. Can't we package and
> ship Webkit ourselves along with QGIS, if it really is a problem for
> 2.14?
The proper solution will be to implement QtWebWengine as an alternative
to QtWebKit. This will be the future for displaying web content.
Matthias
> Andreas
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
More information about the Qgis-psc
