[Qgis-psc] Redmine -> Github tests
Nyall Dawson nyall.dawson at gmail.com
Fri Jul 1 16:38:33 PDT 2016
On 28 June 2016 at 19:31, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Hi Lists (cross posting to have both community, psc and developers),
> Still busy ways to migrate from Redmine to Github possibilities, we play
> with some options. Wanted to sent some ideas to the lists of current status:
> Chatting to Matthias (who did a first import script based on Redmine
> issue.xml imports [0][1]).
> Chatting to Juergen (who did an import script based on table exports of
> the Redmine database [2]).
> Who both hit the Github-api-throtteling limit from Github [3] and
> stopped there:
> - max 60 api-search queries per minute
> - max 5000 requests per hour for other api calls
> We had a little chat to github support, we were pointed to a different
> api [4]
> Receiving python script from Juergen, and his plan to get as much
> information from Redmine as possible by:
> - creating a (sqlite) redmine.db with dumps of nessecary tables from
> (mysql) redmine.db
> - creating 'lookup'-tables for different mappings, eg map Redmine-users
> toGithub-users. Have the Category-strings mapped to their id's AND
> mapped to Github-labels etc etc.
> - write a python script which queries the db and (via github api)
> creates issues with exact the same issue-numbers as we have in Redmine
> - add labels to a Github test repo as 'mapping to Redmine' things like:
> status, prio, etc etc
> My conclusion: if I/we invest enough time into this, I can do further
> scripting and just import the issues in blocks, just enough to not hit
> the limit.
> I hand crafted 2 issues:
> https://github.com/rduivenvoorde/temp/issues/17
> https://github.com/rduivenvoorde/temp/issues/18
> based on http://hub.qgis.org/issues/10755
> To show/see some possible options:
> - one Redmine comment = one Github comment (as in #17)
> - all Redmine comments in one Github comment (as in #18)
Another huge +1 in support of your efforts. Fantastic stuff!
My preference would be to the one redmine=one github comment version (#17).
Nyall
> You can see all possible labels if you try to create a new issue in the
> repo:
> I tried to minimize the number of Labels, but tried to mimic most of
> Redmine's.
> By adding a number in front of it I hope we can instruct issuers to add
> for example at least number 1 to 5 labels. And they are ordered by that
> number in the Github views, making it maybe easier to 'read' them in an
> apparent order.
> All imports will be done by a 'QGIS-redmine-import' user.
> All attributions will be done based on (Redmine) Name and (if available)
> Github userid (I thin we should leave email addresses away)
> References to commits and pr's can be mapped.
> Assignee's can be set on Github userid's
> Attachment info can be copied (url's to original attachment) BUT(!) the
> api does not provide a way to add those. This can only be done via
> Webinterface...
> The plan is to take a couple of complex issues and fine-tune a script
> till everybody is satisfied with result.
> To do this work I need:
> 1) full backup of community that this is the way to go
> 2) help / feedback on first tests or coding
> 3) some time/days? (after 2.16 packaging: 8th july?) to freeze Redmine
> and dump tables again
> 4) some encouragement
> Already done: taking the 4079 users of Redmine, and checked with Github
> if they have a user with the same email OR userid... Only 321 matched...
> So also needed (separate threads/emails?):
> - everybody check this list and see if he/she can match him/herself and
> sent me his/her right Github id together with the Redmine one
> - input/comments about current Labels
> - if we miss something if we do it like this
> Not sure how to channel this, but thought to sent it like an email
> Regards,
> [0] https://github.com/m-kuhn/rm2gh
> [1] https://github.com/m-kuhn/QGIS-Test/issues/
> [2] https://github.com/jef-n/rm2gh/issues/
> [3] https://developer.github.com/v3/#rate-limiting
> [4] https://gist.github.com/jonmagic/5282384165e0f86ef105
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc mailing list
