[Qgis-psc] QGIS 2.16 sponsored bugfixing report
    Tim Sutton
    tim at qgis.org
    Wed Jun 15 01:34:19 PDT 2016
Hi
Awesome stuff Nyall. I added an entry to the changelog including your list below. Ill do the same with the other dev’s worklogs when they share them.
Regards
Tim
> On 15 Jun 2016, at 07:59, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> I've just exhausted my allocated time for QGIS 2.16 bug fixing. During
> this time I've fixed a bunch of stuff, including a few blockers +
> cleared most of the outstanding issues filed against vector joins.
> Here's the full list (sorted by priority):
> - Fix broken projective transform in georeferencer (#14551 - severe)
> - Fix selecting features by radius fails (#14748 - severe)
> - Fix incorrect area calculation for polygon (#14675 - severe,
> although very unlikely to occur. Unit tests added to cover this edge
> case)
> - Fix dock widget layout (#15011 - severe)
> - Fix crash in arrow symbol layer (unreported)
> - Fix crash when creating invalid join (unreported)
> - Fix parameterised SVGs not shown for composer arrow items (#14997 - high)
> - Classifications on joined fields should only consider values which
> are matched to layer's features (#9051 - high)
> - Always use string comparison in expressions for string fields (#13204 - high)
> - Fix home dir being added as default svg and template path (#14662,
> #14652, #14883 - high)
> - Fix crash when using inverted polygons with heatmap renderer (#14968 - high)
> - Save raster symbology values with full precision (#14950 - normal)
> - Actions are not enabled when loading layer with default style
> (#13910 - normal)
> - Remove "attribute table" text from dialog title (#14959 - normal)
> - Fix cannot deactivate customization widget catcher (#9732 - normal)
> - Fix arrow symbol layer head width/height flipped (#15002 - normal)
> - Fix joins are not recreated when loading project with bad layers
> (#10500 - normal)
> - Invalidate join cache when layer is modified (#11140 - normal)
> - Correctly support joins using virtual fields (#14820 - normal)
> - Fix virtual fields which depend on other virtual fields may not be
> calculated in some circumstances (#14939 - normal)
> - Fix rule based labels not shown when using python expression
> functions (#14985 - normal)
> - Auto refresh when symbol levels changed in style dock (#14861 - normal)
> - Fix style dock button not synced to dock state (#14862 - normal)
> - Fix issues rendering SVG with text (#14644, #14794 - normal)
> - Ensure data defined button displayed fields are always up to date
> (#14809 - normal)
> - Fix cannot set shortcut for zoom in (#14958 - normal)
> - Fix inverted polygons and displacement renderer don't allow right
> click on legend items (#14966 - normal)
> - Fix inverted polygon & displacement renderer don't show color wheel
> in legend menu (#14967 - normal)
> - Add missing proxies for legend check behaviour to subrenderers for
> inverted polygon and displacement renderers (unreported)
> - Fix joined attributes can't be used in filter expressions (#13176 - low)
> - Show WKB type in vector layer metadata (unreported)
> - Add missing capabilities strings to layer metadata (unreported)
> - Fix debug noise when using 25D geometry layers (unreported)
> - Fix some status bar widgets could not be hidden via customisation (unreported)
> - Make styling widget live apply remember setting (unreported)
> - Don't show constraint messages when form is in search mode (unreported)
> - Show scrollbars for attribute form as identify results (unreported)
> - Make style dock Apply button always enabled (unreported)
> - Fix some missing auto updates from style dock (unreported)
> I also forward ported a bunch of fixes from Sourcepole's fork.
> Note that I could potentially fit in 1 or 2 days before release if
> desired. I'll be moving house over the next week but could still slot
> in some hours here and there.
> Thanks once again for including me in this work!
> Cheers,
> Nyall
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
QGIS Project Steering Committee Chair
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160615/f466db58/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160615/f466db58/attachment.jpg>
More information about the Qgis-psc
