[Qgis-psc] QGIS 2.16 sponsored bugfixing report
    Sandro Santilli
    strk at kbt.io
    Thu Jun 30 03:14:29 PDT 2016
I've completed my budget hours (and actually spent 13 more) on
a few old critical bugs found on hub. The full list is on the
google document [1], but here's a list of the most important ones:
 - PostgreSQL support for primary key with negative values (#14262)
 - Crash on undo in composer (#11371)
 - Inability to select invalid polygons (#13635)
 - Node tool snapping to random geometries (#13952)
The bugfixes were backported to 2.14 where appropriate and tests were
added when possible.
Once again writing the tests was a big cost, so much that I finally
had to give up on the test for #13952 (node tool), having been over
time for more than I could support.
I hope a new round of testsuite-only activity will be funded sometime
in the future to make it easier for developers to secure fixes, and maybe
then make it mandatory for a test to come with each fix.
Thanks again for the opportunity !
[1] https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaTwt-eDit8YvReB0/edit#gid=1772346068
--strk;
More information about the Qgis-psc
