[Qgis-psc] Websites moved + https
    Alessandro Pasotti
    apasotti at gmail.com
    Sun Dec  3 23:58:23 PST 2017
On Mon, Dec 4, 2017 at 8:54 AM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 03-12-17 23:43, Alessandro Pasotti wrote:
> >     You are right, the installer can't handle it. Whenever the server
> >     returns the
> >     301 page, the installer assumes it's a corrupted zip file. I'll try
> >     to fix it
> >     soon, maybe within next few days, but I can't promise.
> >     Anyway, the installer connects to the repository via https for a
> >     long time, so
> >     the only reason for the redirection is the plugin download urls are
> >     hardcoded
> >     as simple http:// Alessandro, shouldn't they follow the same
> >     protocol? Fixing
> >     it will solve the problem as well.
> > I'd prefer to not double the cached files but I'll see what I can do.
> >     Btw. please note QGIS caches the repositories, so after changing the
> >     download
> >     urls, we still need to clear the cache in the Options dialog ->
> >     Network ->
> >     Cache settings (I'm not sure what's the cached data lifetime?).
> Yes, though it would be nice to have this fixed in the PluginManager
> too, the safest way is to let the plugin-website always return
> plugins.xml with httpS-url's (independent on if the request was http or
> https).
That's much easier to do, Richard if you have time you could just try to
change http->https in the bash script that builds the cached files (ping me
in case you have any problem).
> In that way, also older QGIS/PluginManager versions will work, as they
> can request a http repo, but get https url's back, which then do not
> have a redirection need anymore.
> Then we can in near future do the http->https request again (after the
> caching time).
> Am I right?
> Regards,
> Richard
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171204/a765d613/attachment.html>
More information about the Qgis-psc
