[Qgis-psc] Performance regressions (was QGIS 2.18 bug fixing effort)
Paolo Cavallini cavallini at faunalia.it
Wed May 24 05:29:25 PDT 2017
Il 24/05/2017 14:25, Matthias Kuhn ha scritto:
> I think this is still usable (qgis_bench IIRC).
> What it does: give usable measurements when executed on the same
> environment for different projects, different QGIS versions, different
> build parameters, different databases...
> What it not does: produce values that are comparable when executed on a
> non-stable system like travis CI. Performance on this system varies from
> day to day and we are never sure if a code change or some other change
> on the system (hardware, software, operating system...) is responsible
> for some measured "performance regression".
Thanks Matthias for reminding.
So it would be best to run it in an isolated, predictable environment.
Would a VM do? I think we could find the resources for it, even if this
would require having a dedicated server.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
More information about the Qgis-psc mailing list
