[Qgis-psc] 2018 grant voting is closed
Marco Bernasocchi
marco at qgis.org
Tue Jun 19 04:54:46 PDT 2018
Please note that this does change the results of the approved grants
cheers
Marco
On 19.06.2018 13:48, Marco Bernasocchi wrote:
> Hi Anita, not sure if I found a mistake or if I understand your sheet
> wrongly.
> The formula used is:
> =COUNTIF('Form Responses 1'!B$2:B$25, $B3)
> which is the same as the one used in the March 2017 document that had
> 23 respondents.
> shoulden't this year be:
> =COUNTIF('Form Responses 1'!B$2:B$31, $B3)
> Beside that it looks good to me.
> Cheers
> Marco
> On 19.06.2018 13:05, Andreas Neumann wrote:
>> Hi Anita,
>> Thanks for organizing the whole QGIS grants thing and for doing the
>> scores.
>> Even though we communicated 25k € for grants, I think we can also
>> commit to 29'5 k. Our financial situation allows it.
>> So for me, it would be ok, to communicate the results.
>> Personally, I would have had some other priorities than the voting
>> results (e.g. infrastructure stuff like "setting registry" or "QGIS
>> server OGC compliance ...") are more important to me than "Charts and
>> drawings on attribute forms" or "R provider". I also thought that for
>> the latter two, are more likely to find alternative financial
>> resources - but of course - this is democracy and I will certainly
>> and happily also use the "charts and drawings in the forms" - once
>> they are available ;-)
>> Thanks and greetings,
>> Andreas
>> On 2018-06-18 11:36, Anita Graser wrote:
>>> Hi,
>>> The grant voting form is now closed. We received 29 votes from 18
>>> community representatives and 11 user group representatives.
>>> I've run the numbers to determine the successful proposals but I
>>> think we should have at least two more PSC members cross checking
>>> the results before publishing them:
>>> https://docs.google.com/spreadsheets/d/1e72Z_3jQgCF4cPF6L77W-VptpJX0wSwjFI1TIvGttLU/edit?usp=sharing
>>> Please have a look and let me know if you confirm. My plan would be
>>> to announce the successful proposals on Sunday 24th June.
>>> Regards,
>>> Anita
>>> Qgis-psc mailing list
>>> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Marco Bernasocchi
> QGIS.org Co-chair
> http://berna.io
Marco Bernasocchi
QGIS.org Co-chair
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20180619/9e963129/attachment.html>
More information about the Qgis-psc
