[Qgis-psc] Documents for AGM
    Andreas Neumann
    andreas at qgis.org
    Tue Feb 26 00:20:02 PST 2019
Hi Paolo and colleagues,
I finished the documents you should send along with the AGM invitation:
- financial report (PDF), see
https://drive.google.com/open?id=10_RQEniCuESfyhZhXoHpLfpXwyRrr7uv
- financial auditing report (PDF), see
https://drive.google.com/open?id=1v5Tsa-wa6smBSQ0u2KnabNzBnY5bayV1
- revision of our statutes (PDF) - also checked by Tim. See
https://drive.google.com/open?id=14gez-_EWZnKTUuNbNsJr8I0jwpBAYDOV
In addition, Tim and I worked on the AGM invitation itself (
https://drive.google.com/open?id=1kGDfOyNK08zaGh70erjGNmYKcFQTAdDxkwLYFH21lA8
). I also checked the annual report 2018 (
https://drive.google.com/open?id=114ofo3juxXFCKPVBqFuYIz8MB1xhBdXifo9e54V7ovU
) and removed the financial report from the appendix. I think it is better
to have them as two separate documents.
I think that now we are good to send out the AGM invitation to the voting
members.
Thanks and greetings,
Andreas
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20190226/24948245/attachment.html>
More information about the Qgis-psc
