[Qgis-psc] QGIS Plugin website application maintenance
Richard Duivenvoorde rdmailings at duif.net
Wed Mar 13 08:42:56 PDT 2019
Ok, this went better.
Only on the end I see:
    default: Installed 86 object(s) from 1 fixture(s)
    default:
/var/qgis_plugins/venv/lib/python3.6/site-packages/psycopg2/__init__.py:144:
UserWarning: The psycopg2 wheel package will be renamed from release
2.8; in order to keep installing from binary please use "pip install
psycopg2-binary" instead. For details see:
<http://initd.org/psycopg/docs/install.html#binary-install-from-pypi>.
    default:   """)
    default: Installed 2 object(s) from 1 fixture(s)
    default: Traceback (most recent call last):
    default:   File "upload_test.py", line 3, in <module>
    default:     handle = open("HelloWorld.zip", "rb")
    default: FileNotFoundError: [Errno 2] No such file or directory:
'HelloWorld.zip'
The SSH command responded with a non-zero exit status. Vagrant
assumes that this means the command failed. The output for this command
should be in the log above. Please read the output to determine what
went wrong.
So apparently you try to upload the HelloWorld.zip plugin?
And should we use 'psycopg2-binary' already or so?
Richard
On 13/03/2019 16.28, Alessandro Pasotti wrote:
> Sorry, probably a leftover: you don't need disksize for this particular
> vagrant.
> I've commented it out in modernize.
> On Wed, Mar 13, 2019 at 4:25 PM Richard 🌍 Duivenvoorde
> <richard at duif.net <mailto:richard at duif.net>> wrote:
>     On 13/03/2019 15.33, Alessandro Pasotti wrote:
>     > Hi,
>     > Ok, it took something more than one day but I'm done with the
>     porting of
>     > the plugin application to Django 2 and Python 3, on branch modernize:
>     > Vagrant file is ready and working in the main directory, have a
>     look to
>     > the README:
>     > https://github.com/qgis/QGIS-Django/tree/modernize/vagrant_assets
>     > btw, git clone and "vagrant up" should be all you need to get
>     started in
>     > debug mode and ready for development.
>     > Some work has been done on the dependencies, the new requirements
>     are in
>     https://github.com/qgis/QGIS-Django/blob/modernize/qgis-app/REQUIREMENTS_plugins.txt
>     > NOTE: I did not port (and I will not port) any of the other apps (feed
>     > ggregator, user map etc.).
>     Thanks Alessandro!
>     I installed VirtualBox and tried:
>     $ vagrant up
>     Bringing machine 'default' up with 'virtualbox' provider...
>     There are errors in the configuration of this machine. Please fix
>     the following errors and try again:
>     Vagrant:
>     * Unknown configuration section 'disksize'.
>     Googled: to find you need a Vagrant disksize plugin:
>     $ vagrant plugin install vagrant-disksize
>     Installing the 'vagrant-disksize' plugin. This can take a few minutes...
>     Bundler, the underlying system Vagrant uses to install plugins,
>     reported an error. The error is shown below. These errors are usually
>     caused by misconfigured plugin installations or transient network
>     issues. The error from Bundler is:
>     conflicting dependencies fog-core (~> 1.43.0) and fog-core (= 2.1.0)
>       Activated fog-core-2.1.0
>       which does not match conflicting dependency (~> 1.43.0)
>       Conflicting dependency chains:
>         fog-core (= 2.1.0), 2.1.0 activated
>       versus:
>         vagrant-libvirt (> 0), 0.0.41 activated, depends on
>     Any hint?
>     Richard
> Alessandro Pasotti
> w3:   www.itopen.it <http://www.itopen.it>
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc mailing list
