[Qgis-psc] permissions on Travis
Denis Rouzaud denis.rouzaud at gmail.com
Sat Apr 11 05:54:40 PDT 2020
Thanks for the feedback.
Not sure what's the issue.
QGIS is not listed in https://travis-ci.com/organizations/qgis/repositories
<https://travis-ci.com/organizations/opengisch/repositories> (but all other
repos are)
And I cannot configure the Travis app under Github since I'm not a repo
owner.
https://github.com/apps/travis-ci/installations/new/permissions?suggested_target_id=483444
And under https://travis-ci.com/github/qgis/QGIS/settings it seems it
cannot find the branches and I could setup a cron job on master, but
nothing happens.
I'm a bit lost, would be cool if one repo owner could have a look at Travis
config in Github.
Cheers,
Denis
Le sam. 11 avr. 2020 à 08:40, Matthias Kuhn <matthias at opengis.ch> a écrit :
> Marco installed the github app recently.
> Now the repository needs to be migrated, not sure what permissions are
> required (and it's currently under maintenance apparently)
> Matthias
> On 4/11/20 8:34 AM, Denis Rouzaud wrote:
> Ok, i think I partly enabled it.
> So, I need to
> Disable travis-ci.org/qgis/QGIS
> Enable travis-ci.com/github/qgis/QGIS
> Is this correct?
> Cheers
> Denis
> Le sam. 11 avr. 2020 à 07:38, Matthias Kuhn <matthias at opengis.ch> a
> écrit :
>> Hi Denis,
>> We had the same on our own repos. Here is what they replied.
>> Since migrating to the Github App integration everything works fine again
>> for our repos.
>> Thanks for writing in and sorry about this issue.
>> We are currently looking into this development and our Engineers are
>> working to restore normalcy. This mostly affects repositories using our
>> legacy Services Integration (i.e. all .org repos and some on .com are
>> affected). Sorry about this please.
>> In the meantime, please consider migrating to the Github Apps integration
>> available at this link [1].
>> Thank you for your patience
>> [1] https://travis-ci.com/organizations/opengisch/repositories
>> Matthias
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200411/a1bdd23f/attachment.html>
More information about the Qgis-psc mailing list
