[Qgis-psc] Python cookbook revision final report
Anita Graser anitagraser at gmx.at
Fri Apr 17 06:40:26 PDT 2020
Awesome work, Ale!
I assume it would be good to announce the new revised cookbook on
blog.qgis.org?
Do you want to write the blog post or should I prepare something based
on your report?
Regards,
Anita
On 06.04.2020 16:14, Tim Sutton wrote:
> Wow - absolutely awesome Ale, and thank you so much for the additional
> effort you donated!
> Regards
> Tim
>> On 6 Apr 2020, at 13:59, Alessandro Pasotti <apasotti at gmail.com
>> <mailto:apasotti at gmail.com>> wrote:
>> Hi all,
>> first of all I would like to thank you all and all the QGIS sponsors
>> and donors together with the documentation team for making this review
>> process possible. I also wish to thank Martin Dobias for his help in
>> spotting out an issue in one snippet with Plugin Layers
>> To be completely honest, this task took me quite a bit more time than
>> planned, so consider the additional time that I spent on it as a
>> voluntary contribution by me (or QCooperative as you prefer :)
>> As it was initially planned I was able to review all the code snippets
>> in the cookbook and to put them under automated test in CI.
>> Before I started there were 62 tests over ~300 code snippets, we are
>> now at 303 tested snippets (302 on 3.10). Despite my efforts (where I
>> probably lost most of my time) I had to skip a handful of snippets
>> that were running perfectly well when tested manually but failing on
>> the doctest CI process:
>> - task manager tests (1 out of 3 on master, 2 out of 3 on 3.10)
>> - all standalone application tests (because the mocked application is
>> already started globally and it cannot be re-initialized)
>> Note that for a few of the most complex snippets the test coverage is
>> not 100% because the test does not really cover all execution paths.
>> I didn't have time to go through a reorganization of the text contents
>> but I did quickly read all the texts and I made some small
>> modifications to update the contents where the API had substantially
>> changed from the original texts.
>> A few snippets had to be updated because of changes in the QGIS API or
>> because of the deprecation of a the methods, CRS handling in
>> particular due to the proj6 switch, but there were also other places
>> where I had to make small changes.
>> I've found just 1 syntax error in the whole code!
>> The changes have been backported to the 3.10 branch.
>> Last but not least, I couldn't resist to add a few sections and to do
>> an more in-depth review of the server Python cookbook section, I
>> reorganized the material about plugins and I added snippets and short
>> introductory texts about the new modules and OGC APIs architecture.
>> A final personal consideration:
>> I think that the cookbook is a great source of information, not only
>> for PyQgis begginers or plugin developers but also for C++ developers:
>> it contains a lot of information about the internals of the QGIS API
>> that you cannot really find anywhere else.
>> It could probably benefit from a reorganization of a few sections but
>> it is already a great resource as it is.
>> Cheers
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> *Tim Sutton*
> *Co-founder:*Kartoza
> *Ex Project chair:*QGIS.org <http://QGIS.org>
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
> I'd love to connect. Here's my calendar link
> <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200417/1bd14376/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200417/1bd14376/attachment.jpg>
More information about the Qgis-psc mailing list
