[Qgis-psc] PyQgis Cookbook revision
DelazJ delazj at gmail.com
Thu Feb 27 01:20:53 PST 2020
Hi PSC,
I didn't want to ask during the feature freeze since I know Alessandro
would anyway be busy with coding but now that it's over it would be nice to
get a decision from the PSC whether the update of the cookbook as he
proposed (
http://osgeo-org.1560.x6.nabble.com/PyQgis-Cookbook-revision-tp5425519p5425665.html)
could be done.
Fwiw, I don't think that we should postpone that to grant proposal given
that the docs might have their own budget and this fix should not be in
competition with other areas of QGIS.
Greetings
Harrissou
Le ven. 20 déc. 2019 à 15:41, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> In the docs meeting we have talked about splitting/removing the python
> cookbook from the User manual (the same for other sections).
> The advantages would be:
> - We can release each document in separate
> - We can break one of the docs without breaking the others
> - we can have the cookbook more developers-oriented (even in the way it's
> written)
> The disadvantages would be:
> - We would need to set intersphinx in both projects to allow keep cross
> linking between them
> - we would need to duplicate our sphinx project structure, and maintain it
> (themes, makefiles, CI, etc...)
> - If we want to go with translation, we would need to set other transifex
> projects (at the meeting we kinda talked about the real need for
> translation for the cookbook, quickly browsing excelpt for spanish and
> french, most of other languages don't have it translated)
> But anyway, like Alessandro said, the work that needs to be done, can be
> performed in any of the repositories.
> Alexandre Neto
> On Fri, Dec 20, 2019 at 11:29 AM Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> On Fri, Dec 20, 2019 at 12:22 PM DelazJ <delazj at gmail.com> wrote:
>>> Hi all,
>>> Quick points
>> Le ven. 20 déc. 2019 à 11:54, Alessandro Pasotti <apasotti at gmail.com> a
>>> écrit :
>>>> Whether the whole Python developers guide (cookbook + API) is an
>>>> external link or not is probably not so important, except maybe for
>>>> browsability from the main website and search capabilities from the main
>>>> website.
>>>> The intersphinx  extension helps to reach Python API documentation from
>>> within the Cookbook or the User manual. The reverse is not (yet?) true and
>>> I don't know whether it's easy to do.
>>> Both the Python part and the C++ part are actually a mix of three
>>>> separate topics:
>>>> - core development (C++ and core Python plugins and processing core
>>>> algs)
>>>> - independent plugins (both C++ even if they are not very welcome
>>>> lately and Python).
>>>> - standalone applications
>>>> In any event, if I get this right, moving the cookbook to a different
>>>> sphinx project doesn't change much about the cookbook revision work I'm
>>>> proposing to do, we can probably just move the doctest target into the
>>>> python API project.
>>>> But I wonder if moving the cookbook out of the documentation doesn't
>>>> create a problem with translations, I didn't check if there are any for the
>>>> cookbook.
>>>> Every document under qgis/QGIS-Documentation repository is currently
>>> translated.
>> Hm, so I guess this is a blocker, right?
>> @Denis Rouzaud <denis.rouzaud at gmail.com>  given that the system to run
>> CI tests on the Python code embedded in the cookbook is already in place,
>> what are the technical advantages of moving the cookbook into the Python
>> API sphinx project?
>>> Regards,
>>> Harrissou
>>> I think we should bring the documentation team into the discussion, is
>>>> there a better place than this list where they have a better chance to get
>>>> involved?
>>>> Cheers
>>>> Alessandro Pasotti
>>>> w3:   www.itopen.it
>>>> _______________________________________________
>>>> Qgis-psc mailing list
>>>> Qgis-psc at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>> Alessandro Pasotti
>> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200227/b13c4837/attachment.html>
More information about the Qgis-psc mailing list
