[Qgis-psc] PyQgis Cookbook revision
Paolo Cavallini
cavallini at faunalia.it
Sun Mar 1 04:14:14 PST 2020
Hi Harrissou,
I think everybody agrees in improving documentation, both for devs and
for users. Could you ask the proponents to put a formal proposal for
funding?
Cheers.
Il 27/02/20 10:20, DelazJ ha scritto:
> Hi PSC,
> I didn't want to ask during the feature freeze since I know Alessandro
> would anyway be busy with coding but now that it's over it would be nice
> to get a decision from the PSC whether the update of the cookbook as he
> proposed
> (http://osgeo-org.1560.x6.nabble.com/PyQgis-Cookbook-revision-tp5425519p5425665.html)
> could be done.
> Fwiw, I don't think that we should postpone that to grant proposal given
> that the docs might have their own budget and this fix should not be in
> competition with other areas of QGIS.
> Greetings
> Harrissou
> Le ven. 20 déc. 2019 à 15:41, Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>> a écrit :
> In the docs meeting we have talked about splitting/removing the
> python cookbook from the User manual (the same for other sections).
> The advantages would be:
> - We can release each document in separate
> - We can break one of the docs without breaking the others
> - we can have the cookbook more developers-oriented (even in the way
> it's written)
> The disadvantages would be:
> - We would need to set intersphinx in both projects to allow keep
> cross linking between them
> - we would need to duplicate our sphinx project structure, and
> maintain it (themes, makefiles, CI, etc...)
> - If we want to go with translation, we would need to set other
> transifex projects (at the meeting we kinda talked about the real
> need for translation for the cookbook, quickly browsing excelpt for
> spanish and french, most of other languages don't have it translated)
> But anyway, like Alessandro said, the work that needs to be done,
> can be performed in any of the repositories.
> Alexandre Neto
> On Fri, Dec 20, 2019 at 11:29 AM Alessandro Pasotti
> <apasotti at gmail.com <mailto:apasotti at gmail.com>> wrote:
> On Fri, Dec 20, 2019 at 12:22 PM DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>> wrote:
> Hi all,
> Quick points
> Le ven. 20 déc. 2019 à 11:54, Alessandro Pasotti
> <apasotti at gmail.com <mailto:apasotti at gmail.com>> a écrit :
> Whether the whole Python developers guide (cookbook +
> API) is an external link or not is probably not so
> important, except maybe for browsability from the main
> website and search capabilities from the main website.
> The intersphinx extension helps to reach Python API
> documentation from within the Cookbook or the User manual.
> The reverse is not (yet?) true and I don't know whether it's
> easy to do.
> Both the Python part and the C++ part are actually a mix
> of three separate topics:
> - core development (C++ and core Python plugins and
> processing core algs)
> - independent plugins (both C++ even if they are not
> very welcome lately and Python).
> - standalone applications
> In any event, if I get this right, moving the cookbook
> to a different sphinx project doesn't change much about
> the cookbook revision work I'm proposing to do, we can
> probably just move the doctest target into the python
> API project.
> But I wonder if moving the cookbook out of the
> documentation doesn't create a problem with
> translations, I didn't check if there are any for the
> cookbook.
> Every document under qgis/QGIS-Documentation repository is
> currently translated.
> Hm, so I guess this is a blocker, right?
> @Denis Rouzaud <mailto:denis.rouzaud at gmail.com> given that the
> system to run CI tests on the Python code embedded in the
> cookbook is already in place, what are the technical advantages
> of moving the cookbook into the Python API sphinx project?
> Regards,
> Harrissou
> I think we should bring the documentation team into the
> discussion, is there a better place than this list where
> they have a better chance to get involved?
> Cheers
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Alessandro Pasotti
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the Qgis-psc
