[Qgis-psc] Funding to update test environment?
Andreas Neumann andreas at qgis.org
Mon Aug 1 23:28:13 PDT 2022
Hi Nyall,
Yes - this would be possible. We always have some sort of financial buffer,
for unplanned emergency tasks.
Are you willing to work on it, or would you propose someone else?
We have a PSC meeting tonight and can discuss this issue.
Greetings,
Andreas
On Tue, 2 Aug 2022 at 04:36, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> Hi PSC,
> We're currently hitting an issue where the CI on Github is failing
> because it's all based on Ubuntu 21.10, which is now EOLed. To get
> things back on track, we need to update this to a newer (supported)
> Ubuntu release.
> I attempted this a couple of months back, but found that the amount of
> work required to get things passing was non-trivial. (Due to the tests
> which need to be updated for changed behaviour in the newer
> Qt/GDAL/GEOS library versions).
> My estimate is that we're looking at 3-4 days work to do this.
> So I'm wondering if there's any funds available to complete this work?
> (We can't wait for the normal QGIS grant cycle here, as we really need
> a working test environment to keep things stable and moving forward.)
> Thanks for the consideration,
> Nyall
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220802/58a12502/attachment.htm>
More information about the Qgis-psc mailing list
