[Qgis-psc] CI port to 22.04 - complete!
Nathan Woodrow madmanwoo at gmail.com
Thu Aug 11 00:31:24 PDT 2022
That is a massively impressive bunch of work!
On Thu, 11 Aug 2022, 5:21 pm Tim Sutton, <tim at kartoza.com> wrote:
> Wow awesome work Nyall thanks!
> Sent from my iPhone
> > On 11 Aug 2022, at 07:49, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> > Hi PSC,
> > Just reporting back that I've finished porting the CI setup to 22.04
> > (for master at least, the backports are still being worked through the
> > queue).
> > In the end this work involved both a lot of fixes to individual tests
> > to reflect changed behaviour in newer GEOS/GDAL/Qt versions, plus a
> > fair amount of actual bugs fixed in QGIS which were only revealed on
> > the newer libraries.
> > Here's a quick (non-exhaustive) summary of the actual fixes made
> > during this work:
> > - Fixed a crash in the rule based renderer (this one has been plaguing
> > us for a looong time -- it had previously been written off as an issue
> > in the python tests only, but during this work the Qt 6 based tests
> > started failing and led to the actual underlying cause of the crash!)
> > - Fixed an issue in the hub lines processing tool which caused failure
> > to save features when running on newer GDAL versions (caused by newer
> > GDAL rejecting geometries with nan z/m values)
> > - Fix virtual layer provider failing to determine correct field types
> > on some sqlite versions
> > - Fix spatialite provider incorrectly retrieving features with null
> > geometries when we explicitly ask for features within a given extent
> > on newer spatialite versions
> > - Fix 3d layout map exports are completely blank, and setting the 3d
> > layout map to copy settings from a scene completely fails
> > - Fix GDAL vrt items inside zip files don't show in browser
> > - Fix default qml style for raster layers inside zip archives isn't
> applied
> > - Fix loading gdal rasters inside zip archives which also contain a
> > .aux.xml file fails if only the zip archive is added as a layer
> > I also took the opportunity to do a bunch of cleanups to tests, and
> > specifically the way rendering tests were previously relying on the
> > orfeo toolbox cdash server to allow retrieval and comparison of
> > rendered vs expected images. Now it's done via a more modern approach,
> > making the rendered image report directly available as an artifact on
> > the pull request. (There's lots more we could do to make this further
> > developer-friendly). This removes our reliance on the orfeo toolbox
> > cdash server which has been broken for a number of months now.
> > Thanks again for the opportunity to do this work!
> > Nyall
> > Qgis-psc mailing list
> > Qgis-psc at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220811/9866a563/attachment.htm>
More information about the Qgis-psc mailing list
