[Qgis-psc] PyQGIS API docs update & more
Denis Rouzaud denis.rouzaud at gmail.com
Fri Jul 26 05:27:13 PDT 2024
Dear all,
Here is a recap of the work I've recently done for the PyQGIS API docs.
After the removal of QGIS self built docker images, the way of triggering
the build of API docs needed to be reworked.
Now,* API docs are built once a week for all 3 current versions (master,
stable, ltr)*.
To address the growing size of the website (>10gb, hitting limits of Github
pages), now only the 3 current versions are browsable online. Older
versions are downloadable as archives from the corresponding releases on
PyQGIS repo (https://github.com/qgis/pyqgis/releases). Direct links are
available from the main page of the docs:
https://qgis.org/pyqgis/master/#versions-of-the-api
Also, the repo has been renamed to emphasize the fact that it doesn't
actually hold the documentation and is a "simple build tool".
And to finish, a nice feature: *a direct link from the PyQGIS docs to the
source in cpp code to edit the docstring directly in the web browser* (see
in screencast in PR https://github.com/qgis/QGIS/pull/58054)
You'd tell me, it's nice to edit the docs online, but what about sip files?
We have now a* sipify bot in PR* (https://github.com/qgis/QGIS/pull/58057),
you just need to comment with */sipify*, and it will automatically update
your branch (as long as you do not uncheck "Allow edits and access to
secrets by maintainers" in your PR).
See all this at: https://qgis.org/pyqgis/master/
Kind regards,
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240726/3ab81f71/attachment.htm>
More information about the QGIS-PSC mailing list
