[Qgis-psc] Request for review before new release is cut
Sandro Santilli
strk at kbt.io
Fri Jun 21 23:06:16 PDT 2024
On Sat, Jun 22, 2024 at 09:11:25AM +1000, Nyall Dawson wrote:
> On Sat, 22 Jun 2024 at 06:13, Sandro Santilli via QGIS-PSC
> <qgis-psc at lists.osgeo.org> wrote:
> > On June 21, 2024 11:14:59 AM GMT+02:00, "Jürgen E. Fischer via QGIS-PSC" <qgis-psc at lists.osgeo.org> wrote:
> > >On Fri, 21. Jun 2024 at 10:22:14 +0200, Sandro Santilli wrote:
> > >> It's packaging time today but I still have 5 pull requests pending approval reviews:
> > >> https://github.com/qgis/QGIS/pulls/strk
> > >As far as I can tell none of those are fixes for user facing bugs.
> > 4/5 actually are. One has been now merged by now, btw, so 3/4 are now.
> Am I looking at a different PR queue? There's 4 open, 2 of which are
> marked as draft and not ready for review (marked as draft by YOU), and
> one of which is clearly just an improvement for running tests locally.
The draft are so becuase they are using the improvement one, which is
not only for running tests locally but it is for testing access to
PostgreSQL database as a user with restricted privileges.
I've updated its title to reflect what kind of improvements it has:
https://github.com/qgis/QGIS/pull/57802
I do see the problem with PRs changing titles, yes, but it's a
side-product of the slow review process, because I often find myself
with stumbling upon a dozen bugs and trying to find a good approach
to deal with the PR gate (should I file 12 PRs or a single one?).
Based on the assumption that a PR changing a lot of things would be
even harder to review, I usually aim at a smaller-focused PR, which
in the case at hand is "improve PostgreSQL test data bootstrap
script".
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20240622/fc2d5d48/attachment.sig>
More information about the QGIS-PSC
